586,075 active members*
4,164 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Have working servos & amps. Will buy mach 4 but what piece am I missing?
    Feb 2018
    92
    I have a set of Panasonic Minas A4 servo amplifiers and motors. I've managed to wire them up and sending pulses, get the motor to rotate. They have encoders built in. I want to use these to control a CnC mill conversion. (PM-25V mill).
    The trouble is, I'm missing a part of the puzzle. I thought I needed to buy mach 4, but it is a piece of software, and I still need something that can output the signals to the servo controllers to make the motors go...
    The Minas unit takes direction and pulses, but it seems that I need an additional piece of hardware to interpret the commands from the cam software to actually make the motors go to a specific x,y,z location.
    What piece do I need?
    Re: Have working servos & amps. Will buy mach 4 but what piece am I missing?
    Feb 2018
    92
    Ok, so is it fair then to say that mach4 is the G-Code interpreter which then talks to the motion control hardware? Which part of the system controls things like ramping up the speed of travel and such? Obviously, if you're operating 2 motors at the same time you need each to be coordinated.
    Mach4 does all the trajectory planning, and sends low level commands to the motion controller.
    The exception is backlash compensation, which is handled by the controller.
    Note that not all Mach4 controllers currently support all of Mach4's features, so check with the manufacturer.
    Feb 2018
    92
    Thanks for all the info. I think I may go with the acorn system since it's a single source and appears to be more appropriate for my needs.
  1. Mill Upgrade Options - Reuse existing DC Brush amps and servos?
    By Marty_Escarcega in forum Centroid CNC Control Products
    Last Post: 10-07-2016, 06:58 PM
  2. need help selecting servos and amps
    By Daniel Wilcox in forum Automation Technology Products
    Last Post: 12-26-2009, 11:38 PM
  3. Yaskawa ~vs~ Baldor servos and amps
    By Josh Leber in forum Servo Motors / Drives
    Last Post: 06-07-2007, 01:51 PM
  4. Glentek Servos & Amps
    By cnccadcam in forum Servo Motors / Drives
    Last Post: 06-05-2007, 12:49 AM
  5. Cross pollination of controllers, drives/amps and servos
    By Tywash in forum Servo Motors / Drives
    Last Post: 11-29-2006, 08:21 PM
