586,900 active members*
2,798 visitors online*
Results 1 to 2 of 2
    Nov 2011
    Spindle rpm - variations
    Hi all,
    I am running a vertical lathe, EMAG VSC400.
    Because of vibrations I want to use the $TIMER-function to increase and decrease the rpm by 10%
    I tried this but got a syntax error on line 33! (there is no line 33)!
    $AC_TIMER[3]=0
    WHENEVER $AC_TIMER[3]>=6 DO $AC_TIMER[3]=0
    WHENEVER $AC_TIMER[3]<=2 DO S130
    WHENEVER $AC_TIMER[3]>=4 DO S120
    N130 G1 Z50 F.1
    N132 G1 Z49 F.06
    N134 G1 X72 F.1
    N135 $AC_TIMER[3]=-1
    Regards/
    Jorma
    Nov 2007
    359
    Re: Spindle rpm - variations
    The machine has a look ahead function and reads ahead so it is seeing that error somwhere else
    use the "Stoppre" command to make it look to the last line before going forward
    Stoppre
    $AC_TIMER[3]=0
    N130 G1 Z50 F.1
    N132 G1 Z49 F.06
    N134 G1 X72 F.1
    Stoppre
    If the timer doesnt work increase or decrease by declaring the spindle speed as an "R" value and can be changes at random
    S=R900 (value in user global parameter )
  1. With 3Dprinting, why do we need variations of CNC machinery?
    By Maluseth in forum Automation Technology Products
    Last Post: 06-27-2013, 07:27 AM
  2. Tool holder variations...
    By Dave's_Not_Here in forum CNC Tooling
    Last Post: 10-31-2010, 01:46 PM
  3. zay mils variations
    By doc0302 in forum Uncategorised MetalWorking Machines
    Last Post: 11-25-2007, 07:37 PM
  4. zay variations question
    By doc0302 in forum Benchtop Machines
    Last Post: 11-24-2007, 05:15 PM
