586,102 active members*
3,343 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Driving an HuanYang VFD Inverter via 5 Axis Breakout Board on Mach3
Page 2 of 3 123
Results 21 to 40 of 42
  1. #21
    15362
    Re: Driving an HuanYang VFD Inverter via 5 Axis Breakout Board on Mach3
    Quote Originally Posted by Elish View Post
    Thanks for your help.
    I put in mach 3 setting like St v2 manual
    That all appears to be correct, the only thing now is to check the voltage and see what you have at the different, and with the filter change in the VFD Drive you may be able to get it closer, this won't help much if the PWM output voltage is to far off
    Mactec54
  2. #22
    Jan 2019
    9
    What about the RS485 , by connect to RS on the
    VDF .
    I saw that in other forms.
    Is that help?
  3. #23
    15362
    VDF .
    Is that help?
    Yes there is some good plugins to use the Modbus connection for Mach3 and the HY VFD, that will get you control of everything you want and will be much better than the PWM 0-10v from the Breakout Board, you could try and see it you can get it running without the plugin as the HY is slightly different from a normal Modbus setup
    Mactec54
  4. #24
    Elish Guest
    Can you please send me from where I can buy it
    - - - Updated - - -
    And thanks a lot you really helped me .
  5. #25
    15362
    - - - Updated - - -
    Here is one you can look at give you the complete setup Mach3 plugin for Huanyang VFD | Le royaume d'éole
    Mactec54
  6. #26
    Elish Guest
    Thanks a lot my friend. ????????
  7. #27
    Apr 2019
    7
    Hei Guys,
    Can anyone help me to wire VFD to BoB?
    Thank you.
  8. #28
    15362
    Quote Originally Posted by view2 View Post
    Hei Guys,
    Thank you.
    You will have to check the outputs for PMW and 0-10v to see what each is doing, and to which one you will be using
    Buy testing 0-10 do a M3S12000 in your control MDI and it should measure 5v or near to 5v and at M3S24000 should be around 10v
    Some of the PMW outputs are from 0-5v which you can use also if it is working like 2.5v output for M3S12000
    For the ON /Off one of the Relays can be used Test which one is configured in Ports and Pins
    This Relay connects to FOR and DCM on the VFD Drive use twisted pairs of wires for this connection, this is just a switch no voltage is required in the connection for ON / OFF
    Once you find which output is working for Speed Control you connect this output to the VI and ACM on the VFD Drive
    There will be some VFD Parameter's to change for remote control depending on what voltage you end up using 0-5v or 0-10v
    Mactec54
  9. #29
    Apr 2019
    7
    Thank you "mactec54".
    I've checked the voltage on BoB.
    0-10v is 10.46v
    0-5v is 4.67v
    First I've wired like this:
    P1-PWM to VI in VFD
    GND to ACM in VFD
    Relay2 On/Mid to FWD and DCM to VCD
    When run spindle I have difference between Mach3 and VFD display (lower in Mach3) let say 19380 in Mach3 and 24000 in VFD
    After, I've wired different:
    0-10V to VI in VFD
    GND to ACM in VFD
    When run spindle the difference is less, but still is (now, higher in Mach3) let say 24000 in MAch3 and 23700 in VFD
    I've change the paramenters also in VFD.
    I've set also Output 2 to control the spindle.
    I think somethink is wrong here (maybe the BoB or my settings)
    I am confused with this board because the Relay is P2 and the output number again P2
    In my case, Relay P2 is my Output number 2?
    The pictures with the BoB are attached in the previous post above.
    Any idea?
  10. #30
    15362
    0-10v is 10.46v
    0-5v is 4.67v
    P1-PWM to VI in VFD
    GND to ACM in VFD
    0-10V to VI in VFD
    GND to ACM in VFD
    Any idea?
    PWM should never be connected to VI, unless you know what the output is, only 0/5v or 0/10v should be used for your VFD as it does not support a PWM output
    The VFD reading of 23700 would be the correct number as this is frequency related, this is saying the output voltage from the Breakout Board is a little low which is quite normal for these Breakout Boards, it is possible to adjust settings in Mach3 which can help this a little
    The Relay you just have to pick one that is working it is just an on/off switch
    There should not be any Parameters to change in the VFD drive related to the speed , they normally work ok at the Default settings
    Mactec54
  11. #31
    Nov 2017
    4
    Do you know if I can run 5 axis (4 with slave) and switch the spindle on/off if I remove the BOB jumper? It's unclear to me how the BOB relay is routed. Is it routed to ON/OFF-NO,ON/OFF-C to switch the spindle *AND* optionally to the 5th axis depending on jumper position or is it routed to ON/OFF-NO,ON/OFF-C to switch the spindle *OR* optionally to the 5th axis depending on jumper position? The former would allow 5 axis use with spindle switching the latter would not.
  12. #32
    Feb 2022
    5
    Hi guys,
    I'm working on a PrintNC and I liked the whole process of doing it. Now finetuning it is getting a headache, maybe someone out here can help me.
    Details:
    - VFD Huanyang
    - 2.2Kw Spindle
    - Mach3 BoB 5-axis
    - Here a link to a short clip from the software when I'm running my Spindle https://www.dropbox.com/s/t7tsozdsg3..._0863.MOV?dl=0
    I've connected the VFD tot the BoB as shown attached.
    I've set my VFD-parameters as following;
    PD000=0 for Parameter unlock ( 1 ) for Parameter Lock
    PD001=0 (1 For Remote Control) ( 1 For 0-10v Terminal Control or Remote Trim Pot Control ) ( J1 Also Needs to be set for Terminal Control )
    PD002=0
    PD003=400
    PD004=400
    PD005=400
    PD007=20
    PD008=220 (Motor Rated Voltage)
    PD009=15
    PD010=8
    PD011=120 ( 100 Minimum Setting with Quality VFD, 120 is Safe)
    PD13= 08 ( is for Factory reset, Only use this to set VFD to Factory Default Settings )
    PD014=10 ( Acceleration Adjust to suit)
    PD015=10 ( Deceleration Adjust to suit) ( PD15 is ignored IF PD26=1 Then the Spindle will Coast to a Stop)
    PD141=220 ( Motor Rated Voltage )
    PD041=8 ( Carrier Frequency )
    PD142=7 ( Motor Max Amps for 1.5Kw Spindle)
    PD143=2 ( Motor Number of Poles)
    PD144=3000 (Max Motor RPM) =3,000= (24,000)
    PD70=0 ( This may need to be set to 1 if Control Voltage is 0-5v )
    PD72=400
    PD73=120 ( 100 Minimum Setting )
    I'm not sure about the settings in Mach3. and I can't figure out what I'm missing or doing wrong in order to get the Spindle-speed controled in Mach3.
    Any idea's/solutions?
  13. #33
    Jan 2018
    1516
    Quote Originally Posted by F3rry View Post
    Hi guys,
    Details:
    - VFD Huanyang
    - 2.2Kw Spindle
    - Mach3 BoB 5-axis
    - Here a link to a short clip from the software when I'm running.
    What exactly are you asking?.
    It sounded like it worked.
    If due to rpm readout, you won't see an rpm reading in Mach if you have no feedback to bob.
    If stopping early, it's prob to do with the relay, the on-board one can be finicky.
  14. #34
    Feb 2022
    5
    Quote Originally Posted by dazp1976 View Post
    With current configuration I’m unable to control spindle-speed in Mach3. My question is if someone with given details is able to pin-point missing/wrong settings.
    The spindle is starting and stopping controlled by Mach3, but I can’t controle spindle speed. There’s only one speed now (I think 24000rpm) and nothing in between.
  15. #35
    Jan 2018
    1516
    Are you sure you should be wired into VI?.
    Are you sure it shouldn't be AI instead?.
  16. #36
    Feb 2022
    5
    Did try that just now; spindle runs, but in Mach3;
    RPM = 0 (on VI it would put random numbers on screen when clicking on 'minus' or 'plus');
    S-ov = 0 (on VI was 100 or less when clicking on 'minus')
    Spindle Speed = (on VI was 100)
  17. #37
    15362
    VI and ACM is correct
    Mactec54
  18. #38
    15362
    Do you have the Parameters set for Remote control plus J1 Jumper must be in the correct Position
    Before you connect to the VFD Drive you must have the 0-10v working at the Breakout Board if not and you spindle starts at a low speed you can damage it so get the 0-10v output working and then connect to the VFD Drive
    You normally test the output in MDI mode M3S12000 should give you around 5v Check with different RPM setting to see what the output Voltage is.
    Have you set the Pulley ratio in Mach3
    What do you have to PWM set to
    Mactec54
  19. #39
    Feb 2022
    5
    I'm gonna try my luck with a RS458 usb, ordered it today, will be here tomorrow.
    Thx for helping me!
  20. #40
    15362
    Thx for helping me!
    You have to have the HY Plugin for that to work in Mach3
    Mactec54
Page 2 of 3 123
  1. Motors not moving on mach3 using 6 axis breakout board
    By Freddo2016 in forum Mach Software (ArtSoft software)
    Last Post: 05-10-2017, 10:56 AM
  2. Sainsmart 4 axis mach3 USB breakout board plugin
    By Ctimbs in forum CNC Machine Related Electronics
    Last Post: 12-26-2016, 08:00 PM
  3. Replies: 1
    Last Post: 11-20-2016, 04:58 PM
  4. Replies: 0
    Last Post: 02-16-2016, 01:45 PM
