Re: "Regular" Drill Bits in a CNC
If you are talking about carbide masonry drill bits, no, not the right geometry for that type of work. That is not to say that they can't be used in metal, just not in that application, they do have a use in removing broken taps/drill bits and drilling hard metal, but manually. The other problem is getting a router spindle down to 500 RPM is going to be next to impossible unless you have a very special spindle.
I would spot the holes with a v-bit, or anything you have that would make a good ''center punch'' type divot. The drill the holes to size on a drill press.
Jim Dawson
Sandy, Oregon, USA
