586,103 active members*
3,289 visitors online*
    Dec 2014
    187
    40 watt tube on a 100w Power supply
    Yes possibly a silly question but unless you ask you don’t know. I have a 100w Lazer that’s going to be spare soon so I was just going to put a 40w tube in it without replacing the Power Supply and use it just for engraving.
    Nov 2010
    787
    Re: 40 watt tube on a 100w Power supply
    Quote Originally Posted by KenR60 View Post
    Do not do it. You will destroy laser soon.
    CNC lasers, constructions, service
    Aug 2016
    119
    Do you have specifications on your current power supply? Specifically trigger voltage and mA ratings? It would be risky, but if the 40w tube specifications and the power supply voltage are compatible, then you could drive the lower power tube from the higher power supply. BUT you loose fine control over the power because you'd be confined to using a much narrower band of the total useable mA range and you'd loose fine control over greyscale raster images and the like. And of course you have a power supply that could easily damage your tube. You'd also need a mA meter so you can monitor the tube power. So technically yes, practically I wouldn't risk it myself as there's a lot that could go wrong.
    Dec 2014
    187
    Thanks for all your information, cheaper to buy a 40w power supply then risk it :-)
    Nov 2010
    787
    That`s right.
  1. RECI 100W tube with HY-T150 (150W Power Supply) : is it possible ?
    By medmouncef in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 05-25-2017, 11:29 PM
  2. 50 Watt Power supply connections question
    By Devoreg in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-29-2016, 05:30 AM
  3. Rapid Loss of Cutting Power- New Tube, Fairly New Power Supply
    By scrappyjedi in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 02-23-2016, 01:24 AM
  4. poor power on 100w reci tube. tube is new. 1290 laser.
    By nate in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-05-2015, 07:31 PM
