586,077 active members*
3,591 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Mitsubishi M64 Controller E84 CAN'T IN/OUT problem
    Oct 2015
    5
    I have a Vertical Machining Center with Mitsubishi M64 Controller. Two days ago, the controller lost all parameters because of the faulty of 3.6V lithium battery. Then I have tried to replace the batteryand restore all parameters with the backup in memory cassette. After restored, now having a problem with HOST menu under DIAGN/ IN/OUT. "E84 CAN'T IN/OUT" alarm keep appeared in the HOST menu and cannot be removed.
    Please help
    Sep 2017
    139
    Re: Mitsubishi M64 Controller E84 CAN'T IN/OUT problem
    kindly reconfigure the host and check again
    Oct 2015
    5
    Quote Originally Posted by navinbhas View Post
    Hi Navinbhas, Thanks for your response, I have tried to reconfigure the host, but the problem still there, any other method?
  1. Mitsubishi ladder for m50 controller AO
    By frith in forum Uncategorised MetalWorking Machines
    Last Post: 09-30-2021, 09:08 AM
  2. Mitsubishi M64 Controller HOST E84 CAN'T IN/OUT problem
    By wlun in forum Mitsubishi controls
    Last Post: 02-10-2018, 05:41 PM
  3. Mitsubishi M3 Controller with EUMATCH-800P
    By groundaudio in forum Knee Vertical Mills
    Last Post: 05-17-2015, 04:56 PM
  4. Warthog w/Mitsubishi controller
    By gregj1 in forum Uncategorised WoodWorking Machines
    Last Post: 12-10-2013, 07:23 PM
  5. controller for Mitsubishi MR-J2 drivers
    By cncor in forum Controller Cards
    Last Post: 10-11-2010, 12:08 PM
