Has any see or made a diy Digitizer used in conjunction
with a vac table clamp . This is what i want to do...
I have object ...place it on vac clamp, any which way on the clamp turn on the clamp . Now I want to use the Digitizer to locate the outer corners or
outline the object have mach 3 .. auto adjust the ref point to the object on the vac table?i
Then have it proceed cutting it out.
