586,069 active members*
3,431 visitors online*
IndustryArena Forum > WoodWorking Machines > Wood Lathes / Mills > Convex Cutter for wood lathe machine
    Feb 2018
    Hello everybody! Can you help to solve me a little newbie problem. Is it possible to use Convex Cutter as in the picture with hobbyist cnc machine or its only for metal work?
    Re: Convex Cutter for wood lathe machine
    No picture.
  1. High efficiency cnc wood lathe machine with engraving milling functions
    By Amandadu in forum Automation Technology Products
    Last Post: 03-31-2017, 03:56 AM
  2. CAM Software for Wood Lathe with Swivel Cutter
    By DanielDK87 in forum Uncategorised CAM Discussion
    Last Post: 01-24-2016, 08:24 AM
  3. Paper cutter and wood work cnc machine
    By linda_roctech in forum Roctech CNC Routers
    Last Post: 12-23-2014, 03:40 AM
  4. G03 or G02 for Convex Cut on CNC lathe??? Sigh
    By coltac in forum G-Code Programing
    Last Post: 03-29-2014, 12:08 AM
  5. Looking for a Convex Cutter
    By jecnc in forum CNC Tooling
    Last Post: 11-14-2011, 10:50 PM
