586,065 active members*
4,795 visitors online*
Results 1 to 6 of 6
    Feb 2018
    Problem with engraving
    Hi Guys,
    i have laser JQ1390 and i wil try to explain my problem and nobody can find what happen
    As you can see on the picture, about every 6-8 cm laser engraves bigger letters,it looks like going bigger and bigger and then looks like power going down and engraves nice and smooth ... Light path ok, working table ok, so no idea what going on..
    Thank you guys and waiting yours replyas...
    Feb 2018
    Re: Problem with engraving
    have you tried resetting the machine?
    Feb 2018
    I reinstall software, but did help
    Aug 2016
    119
    Quote Originally Posted by Urte View Post
    Maybe it's just me, but I can't see a picture?
    Feb 2018
    Sorry
    Aug 2016
    119
    So when you say light path ok, and working table ok, what did you do to make sure they were both ok? Clean mirrors and lens, check beam alignment? And what about table height, did you check the distance from the nozzle to the work surface at a few different points? Has the machine been altered recently in any way?
    If everything mechanical and optical is fine in the path, then that narrows down the problem to perhaps the tube itself. If the beam is changing over time, perhaps you have a water cooling problem such as low flow, temperature out of range etc.... Or maybe the tube or power supply is broken.
  1. software problem engraving problem please help
    By jassk in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-19-2014, 09:31 AM
  2. Engraving problem
    By marko rihelj in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-07-2014, 02:51 AM
  3. engraving problem
    By murphyc1 in forum GibbsCAM
    Last Post: 02-27-2014, 08:17 PM
  4. Chinese Laser Cutting and Engraving Machine TS-6040 60w - Engraving problem
    By Andriette in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-24-2014, 03:44 PM
