586,449 active members*
3,361 visitors online*
    Feb 2018
    Exclamation Laser engraver
    Hi
    i was considering to construct a laser engraver for my laboratory project at university, but I can't choose the model itself for constructing. I was looking through these models https://www.bestadvisor.com/laser-engraver, some of them look really easy to perform, but i'm confused a bit whether it worth doing or not. I mean i don't know my capability, it would be nice to here essential recommendations from someone who had such experience.
    Aug 2016
    119
    Re: Laser engraver
    You need to decide a few things:
    1. What materials you want to work with
    2. Etching only, or cutting too?
    3. How big are the objects you want to work with?
    4. That link incorrectly states the laser type. Only the far left is CO2, the others are all laser diodes.
    5. And many other things to consider
    Then there's auxiliary items such as fume extraction and water cooling depending on your needs.
    It's a bit like asking what sort of road vehicle you should buy, bicycle, motorbike, car, truck etc.... There's a large range but they all have things they are good at and things they aren't good at.
  1. gcc c180 laser engraver problem .. laser tube firing a continuous weak beam
    By badrawy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-27-2020, 01:41 AM
  2. Seaking advice to Mod Mini Laser engraver 'NEJE' with GRBL board and stronger laser.
    By BubbleBob in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-31-2018, 11:07 PM
  3. 40W co2 laser engraving cutting machine engraver cutter cnc CO2 Laser Engraver Cutter
    By ecpur in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-27-2015, 08:23 AM
  4. wklaser (Gweike laser) 2011 No. 1 Hot Product--6040N laser engraver display
    By Melody-gweike in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-05-2014, 02:25 PM
