586,068 active members*
4,327 visitors online*
Results 1 to 8 of 8
    Aug 2010
    686
    DIY Pen Plotter Project
    I just started a new series on adding a pen plotter to your CNC.
    https://youtu.be/HwGdwPZBHBc
    Its my hope to add several pen types and eventually even an fully automated plotter.
    see the series here:
    Introduction — Kronos Robotics
    Author of: The KRMx01 CNC Books, The KRMx02 CNC Books, The KRmc01 CNC Milling Machine Books, and Building the HANS Electric Gear Clock. All available at www.kronosrobotics.com
    Nov 2011
    205
    Re: DIY Pen Plotter Project
    Will my printer do that?
    Don
    Aug 2010
    686
    Yes any printer can print an image, but with a CNC we can draw on all kinds of shapes and materials.
    For instance printing on tiles, steel, canvas, or word. I have used my CNC markup various panels I use to hold electronics.
    They can also be used to make some very large templates or blueprints.
    Dec 2014
    640
    Here's mine. I reversed the location of the spring in the pen so that I wouldn't have to worry about any pressure destroying the pen tip, and it maintains constant pressure. It works great.
    Apr 2013
    1899
    Aug 2010
    686
    Just a few updates to the write-up.
    Doing some dry erase testing.
    Simple line drawings are ok with dry erase, but long plotting sequences can have issues as the marker goes over parts that are already dry. The marker has a tendency to erase.
    KRMx02 and the Bird
    https://youtu.be/jtLteq9XyGg
    KRMx02 and the Skull
    https://youtu.be/wavy-XG5a8o
    Dec 2014
    640
    Very cool...I hadn't thought about using a dry erase board as a canvas. A cool way to do a temp drawing.
    Aug 2010
    686
    An Expo dry erase system also has another real nice application. Temporary signs and posters.
    If your CNC is large enough you can draw a 4' x 8' sign for a party or other event. If you cut it down to 4, 1' x 8' you can make some very cool banners.
  1. flatbed cutting plotter,cutter plotter
    By huiteng in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 01-23-2013, 09:42 AM
  2. Laser engraver from plotter project log, with pictures!
    By KTP in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-21-2011, 06:43 PM
  3. Replies: 0
    Last Post: 03-20-2010, 05:37 AM
  4. HP Plotter Help
    By clembrant in forum Solidworks
    Last Post: 12-18-2009, 12:44 AM
  5. using the cnc as a plotter
    By woodman08 in forum WoodWorking Topics
    Last Post: 02-13-2009, 10:36 PM
