586,195 active members*
3,836 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2) > linuxcnc for new setup without a breakout board
Results 1 to 6 of 6
    Nov 2011
    137
    My Question is this has any one not used a breakout board, but connected the output lines from the parallel port pins no.2,3, 4,5,6,7,or 8,9 for step and direction.I understand the breakout board is used for isolation for protection ofr the parallel port.
    Apr 2013
    1899
    Re: linuxcnc for new setup without a breakout board
    Quote Originally Posted by helpmeout View Post
    Using a BoB makes the connections easier, so it is not just about isolation and protection, but sure, if you want to eliminate the BoB it isn't a big issue, as long as you know which wire is which. Though, I really don't understand any good reason to skip the BoB. It's a $5 saving unless you plan on buying a very expensive luxury one, so what's the point?
    May 2015
    686
    Years ago before we used parallel ports for CNC, I made my own version of a breakout board to control a window display that won me some nice crystal. I didn't know what I had made was a breakout board as Mach3 did not exist back then but with a optoisolator chip, a few resistors and some relays, it was pretty trivial to make. I had 8 outputs each with 2 amps at 12 volts. But today, a BoB would have been so much easier. Don't scrimp on the isolation.
    Rod Webster
    www.vehiclemods.net.au
    Nov 2011
    137
    The reason im considering this is Im giong to connect the A4988 drivers to some Nema 17 steppers using the parallel ports pins with linuxcnc, if my lap top wont drive the step and direction pins at the correct level thinking of using pull-up resistors tied to the usb for my 5-volts. I suppose i could use some opto-isolators,and that should help.
    Apr 2013
    1899
    I still find no reason to skip the BoB. Perhaps you have space issues, but other than that, I can't think of any good motives. Remember that a BoB is not just an isolator, it also shapes the signals and converts to the right level using Schmitt-triggers, like the 74HC14. It is a much better solution than pull ups or other "self fabricated" solutions which may and may not work reliably.
    May 2015
    686
    X2, a good BoB will handle either 3.3v or 5.0 v depending on the PC and do the opto isolation for you. It will achieve what your home grown circuit will achieve and more for little cost. There is no reason to try a DIY approach.
    Rod Webster
  1. Replies: 70
    Last Post: 10-02-2023, 11:51 AM
  2. USB Breakout board with LinuxCNC ??
    By nelZ in forum LinuxCNC (formerly EMC2)
    Last Post: 08-02-2017, 09:38 PM
  3. C34R4 Breakout Board Spindle Setup
    By rbraeking in forum Mach Software (ArtSoft software)
    Last Post: 08-02-2014, 06:55 PM
  4. KL-4030 and C10 Breakout Board with KL23H286-20-8B motors and LinuxCNC
    By sbrendtro in forum Automation Technology Products
    Last Post: 04-04-2013, 03:35 PM
  5. Best breakout board to use with my setup.
    By FreeZey in forum DIY CNC Router Table Machines
    Last Post: 04-29-2011, 12:26 AM
