586,061 active members*
4,463 visitors online*
    May 2006
    60
    Accuslide Hardinge CNC retrofit problems
    Upgrade Technology Rock Solid Lathe with Fagor 8025T controller and EMS 606 PC3 spindle driver
    Hello Everyone,
    The lathe intermittently works, the Fagor 8025T controller always completes boot and displays Passed normally, but in the failure mode will not respond manual or programmatic commands.
    I am now in need of the electrical schematics/drawings for the lathe, mostly what is connected to I/O 1
    Something is pulling lines 15 and 16 low and disabling movement.
    I have looked over the connections in and around the controller and have not found any broken wires or loose connectors. But because the lathe has run for quite a few years I mostly suspect any of the moving cables and connectors.
    Thanks in advance for any help this problem,
    Bryan
    Feb 2007
    25
    I have the same problem on a small gang lathe with Fagor 8025T controller.
    The controller will crash shortly after test passed message.
    I am curious what you did so far with yours.
    Are you thinking about a new controller or a retrofit maybe.
    Feb 2022
    Re: Accuslide Hardinge CNC retrofit problems
    I'm looking for a good servo motor card from the 8025 control cabinet one of these machines.
    see numbers in photo
    please contact
    [email protected]
    Feb 2022
    I need this servo card
    Glentek GA369-1CMA ,P/N: 832418-002
    or
    GA369-3
    please email
    [email protected]
  1. Replies: 2
    Last Post: 05-05-2015, 07:53 PM
  2. Another Hardinge HNC Retrofit
    By DennisCNC in forum Vertical Mill, Lathe Project Log
    Last Post: 04-11-2015, 04:44 AM
  3. Hardinge HNC retrofit
    By kz1000 in forum Hardinge Lathes
    Last Post: 06-09-2011, 06:07 AM
  4. Hardinge Retrofit
    By lyfordln in forum Uncategorised MetalWorking Machines
    Last Post: 02-20-2009, 03:27 AM
  5. Fagor Accuslide retrofit
    By Captdave in forum Fagor Automation
    Last Post: 02-18-2009, 04:59 PM
