586,262 active members*
3,537 visitors online*
    Jan 2018
    6
    HOMEING ..Starting point...
    HI ALL
    I AM GOING to build cnc mill and lathe conversion
    i want to asking something
    when i have piece of aluminum for ex 20*20 cm and i want to mill it
    the milling xy table for ex 120*50
    where to put it on the table and how the spindle will move to my piece of aluminum to start milling
    i mean i what to know how to Preparation the cnc to star take the g cood
    any tube
    thanks
    Dec 2005
    160
    Re: HOMEING ..Starting point...
    Mount your aluminum stock on the table anywhere, I will assume that x,y 0,0 is the bottom left corner of the toolpath you want to cut . Now you will move the cutter over your stock at the bottom left corner, and zero the machine. Now the toolpath is in sync with the machine. this is just one way to accomplish that.
    Jan 2018
    6
    thank you
    you means the first thing to do is to zero machine
    and i put the piece of aluminum any where
    and i moved the z or the tool to the y and x of piece of aluminum and i zero machine
    then the g-cood run on the piece of aluminum
    can you guide me to Video tube talking about this operation
    thanks
  1. Need help starting point and ending point wont contact
    By miketola in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-15-2014, 08:04 AM
  2. I need a starting point
    By G02 in forum DIY CNC Router Table Machines
    Last Post: 03-13-2012, 12:05 AM
  3. here is starting point for the new guys
    By spider in forum Casting Metals
    Last Post: 09-10-2006, 06:10 PM
  4. Home, zero, starting point...
    By saturnnights in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-14-2006, 09:57 PM
