I have a couple minor questions before I put power to my BP SERIES II CNC.
I purchased the machine this winter and am just now getting the time to work on it.
I had to pull the head off to get it in my shop.
I have it in position with the head all back on and things cleaned up well.
I noticed a wire missing on the z axis stepper motor and wanted to make sure it is suppose to be there.
It is the jumper between terminals 6 & 2 .The manual shows it but its not there now.
I had the stepper unhooked so It may have been lost then but I am not sure,
The next issue is with the BIJUR lube system.
The manual says the system doesn,t function unless the spindle motor is running and to manually operate the plunger to lube the system while jogging
with the spindle off.
The plunger on mine is already up about 2 1/2" and won,t budge.
Am I looking at its operation wrong or has someone maybe broke the plunger?
I am going to get the phase convertor wired up this weekend and would like to fire her up but need to solve these 2 issues first.
The previous owner said they had trouble with the x & y axis.
They say the 2 axis would feed but would not rapid.
Z axis was suppose to be fine.
Curious as to what the problem is.
Thanks to all for the help getting the head off and back on.
This will be a learning experienc for me,I have been a machinist/CNC operator
For 20 years but never worked on 1.
I converted a Smithy 3-1 to cnc and ballscrews but that was pretty easy with gecko,s and steppers.
Getting this old baby to run again maybe alot more of a challenge.
