586,395 active members*
2,807 visitors online*
    Feb 2018
    Miller 2050 Spectrum CNC wire
    Hello,
    I am using a Miller Spectrum 2050 plasma cutter with a Fireball Comet CNC router, but no plasma arc is being produced. Gas is still flowing, so that is not the cause of the problem. I discovered the Miller's CNC wire is broken, so I am trying to replace it. Problem is I do not think the Miller Spectrum 2050 manual says anything about the CNC controller. I do not know if the CNC controller also needs to be replaced. Any tips on how to test the Miller Spectrum 2050's CNC controller circuit board?
    Mar 2016
    59
    Re: Miller 2050 Spectrum CNC wire
    A few questions:
    Has it ever produced an arc, even just a pilot arc?
    Can you try the plasma cutter in a manual situation to eliminate the plasma cutter as the source of the problem? What I mean here is - can you connect a manual torch to the unit and first, just fire it in the air (Get a pilot arc). If that works, clamp the work lead to some plate and try and transfer an arc. If you are successful, then the issue isn't the plasma cutter.
  1. DTHC II not workign with Miller 2050 need help
    By collinmaune in forum Waterjet General Topics
    Last Post: 03-20-2017, 07:01 PM
  2. Who is using miller 2050 with their plasmacam
    By liftedon37s in forum PlasmaCam
    Last Post: 05-21-2014, 01:31 AM
  3. Replies: 2
    Last Post: 05-24-2013, 03:30 PM
  4. older miller 2050 or new hypertherm powermax 45 plasma cutter?
    By oldman4m80s in forum Uncategorised MetalWorking Machines
    Last Post: 05-06-2013, 02:57 PM
