586,067 active members*
5,257 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > please, i need help with clamping a long thin part on a cnc lathe
    Jun 2015
    4154
    Hello guys, please, i have to replicate the clamping from a classical lathe, where the chuck is tightened by hand, part is tapped gentle to adjust the runnout near the chuck, and the steady rest is adjusted so to adjust the runnout at the far end
    I have to put this setup on a cnc lathe with steady rest
    hydraulic chuck is too strong, so i thought of installing a clasic chuck on the cnc, and in this way i should achieve same setup as on a clasical lathe
    Any thoughts pls ? Is there a way to make things faster, but at least with same stability as on a clasical lathe ? is there a "cnc" approach for this ? kindly
    - i mess with this for a while, and i would really apreciate someone's else suggestions
    - consider that you have to clamp the pull bar, that one that is located between the hidraulic cilinder and the nut of the chuck; this part is pretty similar to that ( without threads ); thank you
    Dec 2013
    5717
    Re: please, i need help with clamping a long thin part on a cnc lathe
    Why not adjust the hydraulic pressure so the chuck does not clamp so tight? It's normally adjustable.
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2015
    4154
    hello Jim even lowest value is too much
    once i had some parts with a much thicker wall, the jaws were around the part almost 300 degrees, and the GO caliber would go only after i would remove the part from the lathe
    Dec 2013
    5717
    Rubber soft jaws?
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2015
    4154
    does this exist ? hmm, it may work ! ?!?! i dont know ... i should craft a set of those, wrap the part nice at almost 360 degrees, and see how it behaves when i tap the part
    i believe that they will help, but i am afraid that it wont be enough, but i hope it will work
    so far i have sense the difference between soft jaws and hard jaws : i can feel how hard jaws are gripping faster and more firmly, while the soft jaws have a delay, because they compress a bit
    that's a nice idea, and i believe that it is worth to try it thank you a lot
    ps : if i dont get the right material, i may destroy those jaws at the 1st clamp; i guess that i will be lucky if i will get it right from the 1st time
    ps2 : perhaps i should consider some metal soft jaws, with the clamping area made of plastic : those should resist without worries at multiple clamping processes; thank you again Jim
  1. CNCing, Long Thin Profiles.
    By dachopper in forum Australia, New Zealand Club House
    Last Post: 10-16-2016, 01:59 PM
  2. long thin turning
    By emmamark in forum RFQ Feedback
    Last Post: 12-07-2011, 01:50 PM
  3. Clamping Inquiry - Long post - No Mentor
    By JWB_Machining in forum MetalWork Discussion
    Last Post: 10-22-2008, 08:39 PM
  4. C3 lathe, X2 mill, Safety glasses, CNC stepper motors and Part clamping
    By yngndrw in forum Uncategorised MetalWorking Machines
    Last Post: 05-24-2008, 09:24 PM
  5. Newbie Q. How to turn LONG, THIN form?
    By pipefettler in forum MetalWork Discussion
    Last Post: 04-19-2006, 05:32 AM
