586,062 active members*
4,524 visitors online*
    Dec 2016
    Positive home issue
    Hello,
    I have converted an XpertMill to run under mach3. I use the limit switches as standard on the machine. That means Y must home to its +1000mm pos. I have set positve homing and the home offset to 1000.
    Now the machine runs positive to the switch, want to back of competely to 0 and then slowly to 1000. How can I set that it backs of only to 990 or so and then slow to 1000again?
    Kind regards
    Ronald
    Re: Positive home issue
    You must be using a custom home macro. By default, Mach3 should only back off until the switch opens, and not do any movement at all.
  1. Mach3 - home switch issue
    By CitizenOfDreams in forum Mach Software (ArtSoft software)
    Last Post: 09-20-2016, 03:59 PM
  2. Atc issue won't raise z past the home
    By NigelFish in forum Fanuc
    Last Post: 05-07-2016, 12:25 AM
  3. Mach3 Limit/Home issue with slaved axis
    By Dub_ in forum Machines running Mach Software
    Last Post: 11-29-2015, 06:16 PM
  4. Replies: 5
    Last Post: 10-30-2014, 01:10 PM
  5. excell vmc y home issue
    By bigbobr in forum Uncategorised MetalWorking Machines
    Last Post: 09-28-2011, 02:30 PM
