586,317 active members*
3,421 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > USBCNC RnR Motion USB Controller/Mach3 Setup with Sculpfun 5W laser
Results 1 to 2 of 2
    Oct 2003
    4
    Hello fellow CNC'ers I built a machine a while ago, and have been looking to add LASER to the routing machine. I found a Sculpfun S9 5W optical power output laser for $179 USD. This is a nice laser and I wanted to hook it up using Mach3 with the RnR USB control board. There was no documentation for the RnR or Sculpfun so I had to experiment, google and scratch my head. If you run into the same problem, I have created a video to document the process - it is easier than I first thought, but took some time: https://www.youtube.com/watch?v=9pr3rpa4RIE
    Too many toys, too little time...
    May 2018
    3
    Re: USBCNC RnR Motion USB Controller/Mach3 Setup with Sculpfun 5W laser
    Has any one Tried this ? I have ordered a 12volt power supply cause I'm running 24volts but I'm not sure I'm reading the drawing in the video right.
  1. Replies: 1
    Last Post: 05-24-2020, 09:24 AM
  2. Datasheet for USB Breakboard CNC 4 Axis (RnR Eco Motion 2.0)
    By cebaldocchi in forum CNC Machine Related Electronics
    Last Post: 05-13-2020, 09:16 PM
  3. Setup and wiring of Mach3 USB 4 axis Motion Controller AKZ250 from Leafboy77
    By MartinBarfoed in forum Stepper Motors / Drives
    Last Post: 04-02-2019, 11:50 PM
  4. Mach3 USB Rnr motion control mpg connection
    By CrazyJane in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-13-2018, 01:21 PM
  5. 4axis USB Motion Controller for Mach3
    By Quorim in forum Benchtop Machines
    Last Post: 05-07-2017, 12:57 AM
