586,103 active members*
3,309 visitors online*
Results 1 to 9 of 9
    Jun 2013
    27
    Laser cutting PU leather... yes or not?
    So, as with much on the internet, half of the information I've found regarding PU leather contradicts the other half.
    I know that real leather is not a problem on the laser, I also know that PVC leather is a bad idea.
    On the other hand, PU leather... I find as many people saying that it engraves great (even Epilog) as they say you should avoid it.
    I have several PVC free leather supplier around, and one specifically says it's 60% Polyurethan and 40% Polyester (which I assume is the fabric the PU is bonded to).
    So what do you think? Is PU leather as bad as PVC leather? Or is PU safe?
    Any first-hand experience?
    Apr 2004
    5737
    Re: Laser cutting PU leather... yes or not?
    No, you shouldn't burn any kind of polyurethane. The resulting fumes are extremely toxic, containing isocyanates and hydrogen cyanide gas - google Bhopal if it doesn't ring a bell). The reason you may not be hearing from people who have done it is because they're dead. Here's a MSDS: https://www.smooth-on.com/msds/files...lex_Series.pdf
    Andrew Werby
    Website
    Jun 2013
    27
    Many thanks Andrew, I will definitively add it to the list of "avoid that stuff".
    Just surprised how avoiding lasering on PVC is common knowledge, but not so much about PU.
    Aug 2014
    125
    Quote Originally Posted by awerby View Post
    epilog, as other manufacturers, specifically list polyurethane as laser safe.
    the isocyanates and ‘hydrogen cyanide gas’ are at lower levels than cutting or engraving wood.
    It’s about as accurate as people wittering on about formaldehyde, when you get more from one apple than in a 300x600mm sheet of 3mm mdf
    Just listing chemicals without reference to the amounts and, more importantly, their constituency, is fear-mongering.
    msds sheets tell you what happens when you burn something in a self-combusting situation - i.e. light it, stand back. That’s not what happens in a laser. PU burns at 220-250C - the laser at the point of ablation is between 600-800C - none of the chemical processes are the same at that temperature
    PU leather is fine to cut and engrave as long as you, the operator, is not breathing in the output. Any decent extraction system will make it safe, for you. Whether you want to vent everything untreated is down to you. I think that, at least, a water bath is advisable when cutting plastics.
    Apr 2004
    5737
    Quote Originally Posted by ledaero View Post
    [That would be alarming, if true. Fortunately, it's not. If you click the "full list" of recommended materials on Epilog's site, https://www.epiloglaser.com/laser-engraving/ there's no mention of polyurethane, as I suspected - companies are generally reluctant to poison their customers.]
    [Where'd you pull this "fact" out of? The only wood products known to generate these chemicals when burned are those treated with polyurethane or isocyanate compounds. Or do you have a source for this stuff?]
    [You eat your MDF, I'll have the apple...]
    [So enlighten us - how much isocyanate comes from burning a gram of polyurethane rubber, versus a gram of pine? Who is your "constituency" for this disregard of people's health?]
    [So you think they're entirely safe, then, as long as they don't reach a certain temperature? What temperature is that, exactly? Can you give us an accounting of all the chemicals generated. including their relative quantities, when a laser burns through a piece of polyurethane at 700C, for instance?]
    [That seems to be something of a retreat from the position you took at the beginning of this little screed. I agree; these chemicals aren't dangerous if nobody breathes or ingests them in another way. But most amateur laser-cutters don't filter their exhaust through a water bath. For them, taking some precautions against using materials with the most toxic combustion products would be a good idea, wouldn't you agree? Or are you set on taking a stand for people's right to poison themselves. and against the "fear-mongering" that advises them to avoid it? Ultimately, your safety is indeed "down to you" - be safe out there, folks, and don't believe every assertion that you read on the Internet.]
    Andrew Werby
    Website
    Aug 2014
    125
    Despite your attempts to belittle with the use of 'screed' and other diminishing words, you're still as wrong as you were with your first post.
    You're welcome.
    Attached Thumbnails Attached Thumbnails Screen Shot 2020-07-19 at 12.02.34 PM.png   Screen Shot 2020-07-19 at 12.07.26 PM.png
    Feb 2023
    I'm quite into leather accessories myself, so I can understand your curiosity. I've gathered that PU leather can be a bit tricky when it comes to laser cutting.
    Jun 2023
    Based on my research, laser-cutting PU leather can pose some challenges. Besides, some folks say it engraves like a charm, while others advise against it. It might depend on the specific composition and quality of the PU leather you're working with.
    To get a definitive answer, I'd recommend reaching out to suppliers who specialize in laser cutting materials or even contacting the manufacturer directly. They can provide more insights based on first-hand experience and help you determine if PU leather is as problematic as PVC leather.
    If you're interested in leather crafting, I recently stumbled upon a cool blog at https://vonbaer.com/blogs/blog/how-is-leather-made/. They have some interesting articles and tips that might pique your interest.
    Aug 2023
    9
    Absolutely, laser cutting PU leather with a UV laser engraver can be a viable option. UV lasers offer precise and clean cuts, minimizing heat damage. However, it's essential to conduct tests on PU leather samples to determine optimal settings for your specific machine and material thickness.
  1. Cnc Laser Cutting Machine for cloth/Fabric/leather/garments
    By Wendydekcel in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-08-2016, 09:59 AM
  2. Laser cutting leather - How to reduce burned edge
    By dalianharley in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-22-2013, 03:52 AM
  3. Leather Laser engraving cutting question
    By echojdlaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-11-2012, 11:37 AM
  4. Can a laser cutting/engraving machine do leather embossing?
    By artworldcn in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-19-2010, 04:54 AM
  5. help and advice needed - laser cutting leather
    By geekinesis in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-03-2010, 09:56 AM
