586,035 active members*
3,910 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > g540 and 201x on same machine?
Results 1 to 9 of 9
    Oct 2013
    22
    Simple question. My fourth axis on the 540 doesn't work. Is there a way to take the signals from that axis, and hook up a 201x to the signals? Has it been done?
    I know I can send it and get fixed, but I'd like to get a bigger motor on my y axis to get some more speed, and I don't think i can do it with the 48v.
    Apr 2003
    540
    Re: g540 and 201x on same machine?
    I know they contain 4 G250 drives. I've never had a need to open the one I have, so not sure if you can simply get another G250 and install it yourself. Take a look and see if it plugs in or is hard wired.
    Other than that, since the G540 has it's own breakout board. My guess is there would be no simple way to use the 201 driver without wiring some jumpers to the G540 board or step/dir only and wiring the power supply separately. But, if you're looking for more power and the 201 can take 80v, using the built in BoB may be a moot point If you have another port and a cheap breakout board and 80v power supply, you can always run it separately. As long as the port/pin setup in your driver software is correct, that will work. Maybe someone from Gecko will chime in with advice.
    Mar 2007
    2083
    when you open the G540's case
    you will find a motherboard with the motor connectors plugged onto four G250 stepper drivers that you can replace your self
    note- the latest version of the G540 uses modified versions of the G250 and G540 mother board
    because the potentiometers used to tune the G250's has been moved and are now on the mother board
    John
    Mar 2007
    2083
    as a plan B
    after having a look at the 201x
    I think you can connect 201x and G540 on one printer port if you used a modified printer cable
    if you make a printer cable out of a ribbon cable and IDC 25 way D-type connectors
    it will be possible to split the ribbon so that the step & direction wires that would of gone to faulty G540 axis
    can be connected to the 201x step & direction inputs
    the 201x common will need to be connected to +5V taken from your PC - a USB cable can be cut to make the +5V available
    Attachment 387306
    John
    Mar 2007
    2083
    here is one possible solution
    for a smooth stepper
    Attachment 387336
    a ribbon cable with two 25pin plugs
    the end plug has wires for pins 8 & 9 cut for the connection to the G540
    the in board 25 pin plug can either
    be connected to a working G540 to control 4 axis
    or a 25 way socket with two wires connected to connect pins 8 & 9 to a G201x
    with its common connected to +5V supply from the PC (or motion controller )
    John
    PS
    for PC printer port to G540 & G201x
    Attachment 387342
    Oct 2013
    22
    Well, that is awesome. Exactly what I was hoping for. Basically I'm stealing the signals from 8 and 9 to feed them to the 201? Correct?
    Thank you!
    Mar 2007
    2083
    yes , without modifying the G540 !
    the IDC connectors save a lot of soldering just in case you have not had a lot of practice soldering D-Type connectors
    https://uk.rs-online.com/web/p/idc-d...ctors/0492642/
    Attachment 387338
Name:	idc sub D.jpg
    taken from the net
    USB cable colour code
    use red wire to power the G201x common input
Name:	USB cable colour code.jpg
    Mar 2017
    926
    I was just about to start a thread with a very similar question for a slightly different reason...
    I want to buy a 400lb table for a moving table machine and I am not sure if my Gecko g540 / nema 23 381oz stepper set-up is up to the job. I wanted to ask if it was possible to add a second breakout board to connect a G-203 to run a more powerful nema 34 for one axis while keeping the g540 / nema 23's for the rest.
    If I understand what I am reading here properly, it sounds like there is a cheaper way to do it if I splice cables and whatnot. If it didn't want to splice and dice cables, is using a second breakout board a viable method of using a 7amp nema 34 alongside a g540 on a Linux CNC machine?
    Mar 2017
    926
    This is the motherboard I was considering:
    https://www.pmdx.com/PMDX-134
    For $55, it allows you to connect up to 4 G-203 drives and, with an additional $10 adapter, it can connect direct to a parallel port, or it can be connected to a breakout board / motion controller.
  1. motor cable cut by machine g540
    By Bri4n in forum Gecko Drives
    Last Post: 07-22-2013, 05:12 PM
  2. Machine Enable G540 EMC2
    By heathric in forum LinuxCNC (formerly EMC2)
    Last Post: 09-16-2012, 11:52 AM
  3. motors not moving Gecko 201x
    By silyavski in forum Gecko Drives
    Last Post: 08-18-2011, 08:17 AM
  4. Machine Enable G540 EMC2
    Last Post: 04-06-2010, 06:04 AM
  5. 201x
    By nofx in forum Gecko Drives
    Last Post: 02-11-2010, 06:15 PM
