586,061 active members*
4,673 visitors online*
Page 2 of 2 12
Results 21 to 27 of 27
  1. #21
    Dec 2007
    578
    Re: Fill in the Blanks Gcode Dynomotion
    Hi Tom,
    Hmmm. The Tab order is not currently easily set in the Screen editor. The Tab order of the Edit Input Controls is fixed. So you must choose them in order and place them on your screen carefully. I see on your Bolt Circle example they sort of jump around.
    What about selecting an operation with arrow keys? Or maybe with inputting a number to select an operation?
    I'm not sure I follow your point. I was saying that it might be very difficult to make all the screens look the same. Let's say we end up with 50 KCode screens that all have a certain size and style. Then the User wants to change his main operator screen to a different size and style. The KCode Screens will then all look different. The only solution I see to this is to have the screens inherit styles and dynamically resize (like C# WPF or web pages), which is way beyond the scope of the KMotionCNC Screen Editor.
    So there would have to be a set Main KMCNC dialog face for the KCode screens to work correctly? If so, i dont think that will be to bad. Would just have to come up with a Main face that is universal but not busy and cluttered. Would the custom 3 page screens work?
    Troy
  2. #22
    Jun 2004
    355
    Is there anybody wanting to test the barebones of my conversational program?
    I've spent a bit time re-working it to create a (hopefully!) reasonable framework to expand from, and am looking for anybody willing to comment on what I've done so far, and to give input on future additions.
    At the moment it only does canned cycles, but I'm currently working on reading the KMotionCNC tool file, so I can get started on adding more milling features (they all involve knowing the tool diameter, so I figure reading it from the tool file will be simpler than having to input it manually).
    Anybody interested, drop me a PM with your email, and I'll send you a link.
  3. #23
    May 2006
    4045
    Hi m_c,
    Please send me a link.
    I will try to get started on adding the automation interface functions to KMotionCNC. I'm thinking we would need to add the following functions:
    - Save Currently Open GCode File
    - Get Open GCode File Name
    - Get Cursor Selection Range
    - Set Cursor Selection Range
    - Load GCode File
    - Run Simulation
    Does that sound right?
    Regards
    TK
    http://dynomotion.com
  4. #24
    Dec 2007
    578
    Hay Tom,
    Is there anything i can do to help? Dont know if you still want me to make more screen sets for examples or?
    Thanks again,
    Troy
  5. #25
    May 2006
    4045
    Hi Troy,
    I'm not sure at this point. It seems m_c is making good progress on his C# program. Unfortunately it would probably be hard to duplicate all that functionality with the KMotionCNC Screens.
    Just a thought. How good at CAD are you? I was thinking some fancy 3D graphics for each operation type would be nice. Some type of translucent 3D image to show what the operation does with all the dimensions marked.
    Regards
    TK
  6. #26
    Dec 2007
    578
    Is part of my day job You want a bitmap?or?
  7. #27
    May 2006
    4045
    Hi Troy,
    I'd suggest a *.png bitmap. You might check with m_c to see what he thinks. Also regarding to size. His screens don't currently have a place for an image.
    Regards
    TK
Page 2 of 2 12
  1. Dynomotion
    By johnpmilleriii in forum Dynomotion/Kflop/Kanalog
    Last Post: 09-14-2015, 06:45 PM
  2. DynoMotion .Net
    By bradodarb in forum Dynomotion/Kflop/Kanalog
    Last Post: 07-10-2015, 07:25 AM
  3. Reversing the fill image or getting the negative fill in TM CAD???
    By lordhelemt in forum Uncategorised CAD Discussion
    Last Post: 07-03-2015, 03:35 PM
  4. TTS Blanks
    By JimsMachining in forum Tormach Personal CNC Mill
    Last Post: 03-07-2015, 07:20 AM
  5. Dynomotion
    By carlcnc in forum Controller Cards
    Last Post: 03-06-2009, 06:16 PM
