586,052 active members*
3,992 visitors online*
    Dec 2017
    Ethernet smooth stepper
    Hello I have a automation tek 4 axis cnc kit with the c10breakout board with mach3 connected via parallel port I get no action . I have Windows 10 64bit have installed drivers for the parallel port card but no communication to mach 3 . Hooked up to my neighbors ess with Windows 7 64 bit and we got movement just wanted to double check if Windows 10 and the warp9 ess kit will work if anybody knows ? Also I'm kinda skeptical on the uc100
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    Re: Ethernet smooth stepper
    You can't use the parallel port with a 64 bit OS.
    Yes, the ESS will work fine in Windows 10, as will the UC100.
    I'd recommend the UC400ETH or UC300ETH over the UC100, though.
    ESS board is good with window 10,
    https://www.automationtechnologiesin...rd-for-mach-3/
    Dec 2017
    Quote Originally Posted by automationtechinc View Post
    Sweet I was hoping so been dead in the water tried everything
  1. G540 with an Ethernet Smooth Stepper set-up
    By GrandpawB in forum Gecko Drives
    Last Post: 05-21-2015, 07:42 PM
  2. G540 with an Ethernet Smooth Stepper
    By dmauch in forum Gecko Drives
    Last Post: 04-04-2015, 06:21 PM
  3. limit switches and ethernet smooth stepper?
    By bit pusher in forum Charter Oak Automation Support Forum
    Last Post: 02-24-2015, 10:05 AM
  4. ethernet smooth stepper
    By daniellyall in forum Mach Software (ArtSoft software)
    Last Post: 08-08-2013, 07:40 PM
  5. Smooth Stepper Ethernet Board - Mach3
    By mrpackethead in forum X3/SX3/G0619/G0463
    Last Post: 05-09-2013, 02:04 PM
