586,058 active members*
3,687 visitors online*
Results 1 to 6 of 6
    Nov 2016
    Problem with Proma THC 150
    Just got a used CNC table using a Gecko G540 and a Proma THC 150 for z control. Everything seems to be working fine except the THC, it reads voltage fine but doesn't output anything or light up the arc/up/down lights on the front of the unit. Same result in test mode, voltage goes up and down but no lights or output with Mach3 showing those three inputs as active high as soon as the THC has power. I'm assuming the worst and have gotten no response from Proma, but I thought maybe someone here knew of a reset procedure or worst case get a recommendation for a new THC. I do have a couple other little things to figure out on the machine, but for now the biggest step is getting a working THC.
    Jul 2014
    4
    Re: Problem with Proma THC 150
    hi turkeh, im in the same situation as you right now, just a little further in the process.
    MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA
    this is my post on the MACH forums, you should find basically all the information you need here to set it up.
    My PROMA will be fully functional on saturday, when my switches get here
    good luck if you have any questions shoot them.
    Nov 2016
    I read through your thread, but it seems like your THC was working in test mode from the beginning. My THC does not perform the test properly, none of the lights on the THC itself light up nor is there any response on the ports themselves.
    Sep 2013
    Quote Originally Posted by turkeh View Post
    I have the same problem with proma thc. Did you find any solution? Thc worked fine about 1 year and suddenly it went broke
    Dec 2017
    82
    the up and down signal on the proma most turn on in test mode.
    you can cut with it and without any setting in mach3 see the lights turn on or off
    Jul 2005
    25
    Maybe a sollution!
    I had the same problem with my brand new Proma THC150!
    BUT, in my case, in my oppinion it where the settings of HU (High Voltage) and de voltage set in the 'default' screen outside the menu.
    When these voltages are right and in the good range it started working!
    I think the THC does not work (in my opinion) when these two values are to to far from each other...
  1. Proma THC SD.
    By MrEmo in forum PlanetCNC
    Last Post: 08-07-2017, 09:32 AM
  2. Proma SD or 150
    By Greolt in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 05-14-2017, 08:30 AM
  3. proma sd PLEASE HELP!!!
    By woz1972 in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 03-02-2017, 02:09 AM
  4. Proma THC Problem!
    By haroutkhaloian in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 11-13-2015, 09:14 AM
  5. Proma THC problem...
    By smokery in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 08-15-2014, 07:34 PM
