586,076 active members*
3,954 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > who can help me with the right software settings cncusb controller v2/04 planet.com
    Feb 2018
    who can help me to provide the right software settings. I have a cnc usb mk2 / 4 portal breakout board, where I have connected 4 drivers for the 3 axis portal (2x X axis, Y axis, Z axis). I have connected 3 limit switches and an emergency stop.
    this all works. the steps / u are set at 320 000 only I can not find the right setting for the speed.
    who can tell me or send pictures where I have all the settings of this program
    (cnc v4.02.39 / i600)?
    these are the data:
    breakout board: cnc usb controller mk2 / 4 2.0
    connected via usb
    software: cnc usb controller V4.02.39 / I600
    3 step driver: set to 2.4 A and 1/8 micriostep (for X and Y axis)
    1 step driver: set to 2 A and 1/8 microstep (for the Y axis)
    3 motors are 2A (for x and y axis)
    1 engine is 1.8 A (for z axis)
    the rush I measured and is 5 mm
    the portal is the high Z series s-1000 from heiz
    This link contains all his details: https://www.cnc-step.com/wp-content/upl ... s_EN-1.pdf
    who can help me do not come out anymore
    Dec 2012
    199
    Re: who can help me with the right software settings cncusb controller v2/04 planet.c
    To calculate the max speed settings, you need to have the self inductance of the motors and the supply voltage of the drivers.
    I thought this is the formula for the Rpm for the motor: Calculation: Rpm = 60 * Voltage * 1000 / Inductance * 2 * motor peak current * steps per rev
    Mar 2017
    1312
    To export your settings file for us to inspect it, please click in CNC USB sw: File/ Export Settings and post it here
  1. Replies: 1
    Last Post: 01-03-2018, 10:13 AM
  2. Replies: 1
    Last Post: 08-17-2017, 06:52 AM
  3. Replies: 3
    Last Post: 06-14-2017, 08:45 PM
  4. Planet CNC MK2 Controller
    By ad64075 in forum Stepper Motors / Drives
    Last Post: 08-30-2013, 04:12 PM
