586,065 active members*
4,451 visitors online*
Results 1 to 10 of 10
    Mar 2010
    621
    Will these bearings work?
    Will a THK bearing HSR20 fit on a THK SR20 460L (gk) rail?
    If not, can someone tell what the compatibility is for either and how to identify them.
    Many thanks
    Adam,
    May 2013
    480
    Re: Will these bearings work?
    HSR and SR are not the same thing. hsr has the balls at 45 degree contact angle, sr has 2 at 90 degrees and two at 30 degrees. the sr rail looks sort of like a dovetail.
    as to how to identify them.. download the datasheets and read them before you buy... don't ask me how i've learned that..
    Mar 2010
    621
    Thanks for the reply.
    So the Bearing has to be an SR to match the rail or vice versa the rail has to be for an HSR bearing?
    Adam,
    Gecko G540, Rack and Pinion Drives-X and A axis, 1/2-10 5 Start Acme-Z Axis
    4-THK HSR 25 Linear Slides, KL23H2100-35-4B, Power Supply-KL-600-48 48V
    May 2013
    480
    no offense but does a square peg fit in a round hole?
    download the datasheets and look at the drawings.
    Mar 2010
    621
    I've already read the datasheet and since its not specifically clear to someone not familiar with the product lines I thought I would ask someone with experience.
    No need to reply if you don't know or don't want to clarify the datasheet.
    ..and no square pegs do not fit in round holes..
    Jun 2010
    4256
    Of course it can. You just start with a slightly smaller square peg ...
    Cheers
    Roger
    Dec 2013
    5717
    Quote Originally Posted by RCaffin View Post
    Cheers
    Roger
    Or a really big hammer
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2010
    621
    Now that the discussion of pegs is out of the way...
    Can I assume from the sarcasm and insult that the simple answer is no they are no interchangeable?
    Jun 2010
    4256
    You want US to download the data sheets and read them for you? Unlikely.
    Cheers
    Roger
    Apr 2004
    733
    The bearing carriage type has to match the rail type/width.
    A SR20 carriage only fits a SR20 rail.
    You cannot mix and match them.
  1. Replies: 1
    Last Post: 01-04-2018, 09:43 AM
  2. Angular Contact Bearings...Will these work?
    By RicknBeachcrest in forum DIY CNC Router Table Machines
    Last Post: 01-06-2011, 03:58 AM
  3. Will this work for linear bearings?
    By luther in forum Linear and Rotary Motion
    Last Post: 06-24-2007, 04:09 AM
  4. Kitamura Work Spindle Bearings
    By coalstove in forum Uncategorised MetalWorking Machines
    Last Post: 08-29-2006, 02:08 PM
  5. Replies: 1
    Last Post: 04-17-2006, 06:20 AM
