586,060 active members*
4,020 visitors online*
    Mar 2014
    1131
    How to properly setup a lathe in SolidCam?
    I've been using SolidCam for some years for milling but I'm very new on the turning worls.
    My lathe is a retrofitted standard lathe. It has a front tool post and spindle turns only in CW direction.
    I found a Mach3 post processor (I'm using Mach4 tho). That's all I have. When I for example create a turning operation and select faces to cut, then I select a cutting tool but SolidCam by default thinks the machine has a turret and the turret is on the back side. Also it thinks the spindle then rotates in CCW. It is a pain to create a very simple operation.
    So, how can I properly setup my lathe in SolidCam? Do I need a .machine file? If yes, I am unable to find one like my machine. Do I need to create mine? If yes, I have no idea how.
    Thanks in advance.
    Suat
    Jan 2012
    36
    Re: How to properly setup a lathe in SolidCam?
    Hi Azalin,
    Yes, when it comes to programming in SolidCAM the VMID (Virtual Machine ID) is crucial for programming to work properly. If you have a local reseller, I suggest reaching out to them. Many times they have some generic posts that are setup per the way your machine works.
    Thank you,
    Darrin
    SolidCAM USA
  1. Replies: 3
    Last Post: 09-17-2017, 09:09 AM
  2. Solidcam: properly adjusting postprocessor arc interpolations, axis accelerations...
    By allenp in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 05-06-2016, 07:06 PM
  3. Replies: 0
    Last Post: 03-07-2016, 07:08 AM
  4. Do you have your stepper limits setup properly? (for noobs)
    By guru_florida in forum LinuxCNC (formerly EMC2)
    Last Post: 07-21-2011, 06:55 PM
  5. Solidcam Turning setup problem
    By Ron Thompson in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 09-21-2010, 01:05 PM
