I'm having trouble getting my 510 machine up and running.
I've manually threaded a wire, and it feeds (although not super smooth). I have a resin bottle on the machine and the DI is < 15uS. I activate touch mode, and the machine wont move, except in the X- direction. it will move in X-. When I crash into something moving in X-, nothing happens, the machine doesnt stop.
Also, I'm trying to manually make a cut just to make sure things are working. I've activated the standard steel .TEC using CT-Expert for 0.01" wire. In manual mode, I press EDM active. This is supposed to produce a EDM signal in manual mode where it should make some sparks. For me, nothing happens when I do this. There are no alarms on the machine. Any thoughts?
