586,096 active members*
3,057 visitors online*
IndustryArena Forum > CAM Software > Esprit > wrap engraving
    Feb 2018
    wrap engraving
    Hi All, I'm using a little older version of Esprit (2016). I am having problems getting Esprit to engrave on a 1.5 dia. bar in a Haas DS-30 SSY. I have tried creating chains off of a solid and use wrap contour, I tried using the engraving in the create menu. None of it has worked. I have never had to do this and I am lost. Any ideas?
    Mar 2012
    20
    Re: wrap engraving
    it would help if you can share the Esprit File.
    Jun 2010
    81
    Re: wrap engraving
    Setup the text for whatever you want like the picture... (Text Entry) Place the text where you want it to wrap the model.... Be sure it's orientated properly using the correct workplane... Once situated, smash the text to line segments... Grab all the line segments and Auto Create chains.... Now grab one of the chains and setup the tool and parameters for wrap engraving... You will change the .997 working dia. to 1.5... Once one is correct, copy and paste in all other text chains...
    It may be easier to create text on the model where you want it and cut it that way...
    Attached Thumbnails Attached Thumbnails Text Entry.JPG   Chains.jpg   Engrave.jpg   Rotary.JPG
  1. How to wrap an imported slt around z
    By Plippy12 in forum FeatureCAM CAD/CAM
    Last Post: 07-31-2013, 10:32 PM
  2. wrap axis
    By NiM in forum Esprit
    Last Post: 07-18-2013, 09:09 AM
  3. Wrap your mind around this one.
    By themuffinman in forum MetalWork Discussion
    Last Post: 05-14-2012, 05:09 PM
  4. Simple Wrap Around Dia. Plz-HELP
    By MassiveTool in forum Mastercam
    Last Post: 02-03-2008, 12:52 AM
  5. 4th Axis Wrap
    By brtlatjgt in forum OneCNC
    Last Post: 12-31-2003, 04:11 PM
