586,108 active members*
3,084 visitors online*
Results 1 to 6 of 6
    May 2017
    Exclamation NEED HELP! AMADA VIPROS 255
    AMADA VIPROS 255 FANUC 18P CONTROLLER MACHINE SHOWS "HYD AMP ALARM".
    HOW CAN I SOLVE THIS PROBLEM.
    PLEASE HELP ME
    Mar 2009
    101
    Re: NEED HELP! AMADA VIPROS 255
    Quote Originally Posted by AKHILKUMAR View Post
    PLEASE HELP ME
    You have 2 large orange doors, Open the door on the left. You will see yellow fanuc rack. Next to the rack 2 black amplifiers they have chrome handle around them. One of them will have red alarm. Left Amp controls ram position valve, right Amp controls high low pressure valve. Only way to clear alarm is to turn control off/on. After reboot will alarm come on instantly? Only after you punch? Any loud vibration noise from the top of the ram? Goto very top of machine remove covers. Check for broken wire on both servo valves. Send me more details.
    Regards,
    Joe
    Mar 2009
    101
    AKHILKUMAR AMADA VIPROS 255 FANUC 18P CONTROLLER MACHINE SHOWS "HYD AMP ALARM".
    PLEASE HELP ME
    Please keep troubleshooting on this main page. It will help others in the future.
    Look at my directions and identify Amp is giving alarm. send picture.
    Oct 2005
    89
    PLEASE HELP ME
    Hello Mr. Akhilkumar,
    Where in INDIA is this machine located ?
    we can troubleshoot the machine on site ....if you require .
    pls get in touch on [email protected]
    whatsapp +91 9404222266
    thanks.
    May 2017
    sir,
    Servo valve abnormal noise occcured when tool change switch turning on
    i cant find any broken wires
    Attached Thumbnails Attached Thumbnails IMG_20180228_101845.jpg   IMG_20180310_141528.jpg   IMG_20180310_141537.jpg   IMG_20180307_122833.jpg
    Mar 2009
    101
    You can see the LSVAMP1 red LED is on. That is bad. The part number is on the right side. You need to remove LSVAMP2 in order to see part number. This LSVAMP1 is used for ram position, It controls the taller servo valve.
    It is possible cable or tall valve are bad. It is most likely 1 of 3. If you turn on machine and ram vibrates for few seconds until amp alarms than it is prob valve. I may have AMP if you need.
  1. AMADA VIPROS 357
    By goyo in forum DNC Problems and Solutions
    Last Post: 10-11-2016, 05:35 AM
  2. Amada Vipros 255 (Fanuc 18-P)
    By rphillips10 in forum DNC Problems and Solutions
    Last Post: 06-01-2016, 04:09 PM
  3. AMADA VIPROS 357
    By Am357 in forum DNC Problems and Solutions
    Last Post: 03-16-2016, 12:46 PM
