586,055 active members*
4,311 visitors online*
    Sep 2014
    7
    RD Works V8.18.01
    I am using Rd works and I am trying to do the same design equally spaced on the front and back of a tumbler on my rotary chuck. In order to center the design up with another feature on the tumbler I am trying to use absolute in the work coordinate setting. When i do this i am getting an error message " Data out of work area". If I use the current position or any other setting it doesnt give me the error but it shifts the location off center and misaligns the design. Any help would be appreciated.
    Apr 2006
    108
    Re: RD Works V8.18.01
    Data out of work area.
    This means that you have created a project that fits the space, but you have moved the origin point to a place that the rest of the project will not fit into the laserqble work space.
    Also pay attention that the laser head will need to swing additional length for acceleration and deceleration of the focal head scan function.
    Ray Scott
    Rabbit Laser USA
    Aug 2018
    28
    The option of absolute coordinates is used so that the design cut is made in the exact position in which it is in the design software grid. It would be necessary to analyze more the design and the way in which you handled it, but unless you change the size of the grid it will give you errors. I recommend you take out the area of the glass and design in plane using the current position option.
    Any questions we can help you, we are:
    BuchiCNC USA
    You can check our CO2 laser cutters here:
    CO2 Laser cutting machines
    If you want a metal laser engraver:
    Laser metal engravers
    Great CNC Router:
    CNC Routers
    Soy tecnico de laser con experiencia.<br />Usuario de maquina de corte laser Buchicnc EVO 14.<br />Usuario de grabadora laser por fibra EVO 5.<br />Usuario de router CNC, con mesa de 3 x 2 mts Auto Tool Changer<br />Diseño mis propios archivos maquinas de corte laser con CorelDraw, LaserCut 5.3, RDWorks V8.<br /><a href="https://buchicnc.com" target="_blank">Estas son mis maquinas de corte láser BuchiCNC</a><br /><a href="https://buchicnc.com/producto/maquina-de-corte-laser-evo-14/" target="_blank">EVO 14</a><br /><a href="https://buchicnc.com/producto/maquina-de-corte-laser-evo-5/" target="_blank">EVO 5</a><br /><br /><a href="https://buchicnc.com/en/" target="_blank">Laser cutters &amp; CNC Routers BuchiCNC USA</a><br /><a href="https://buchicnc.com/en/product/cnc-router-mr-atc-6-standard-line/" target="_blank">CNC Router ATC</a><br /><a href="https://buchicnc.com/en/product/laser-cutting-machine-evo-14/" target="_blank">EVO 14</a>
  1. Replies: 1
    Last Post: 06-29-2017, 07:37 PM
  2. RD Works V8
    By flyingpiggy in forum Laser Control Software
    Last Post: 05-12-2015, 10:47 PM
  3. Replies: 0
    Last Post: 05-01-2013, 05:00 PM
  4. Only Y works correct X don't work Z works one direction only
    By jdgbadenhorst in forum Hobbycnc (Products)
    Last Post: 06-10-2012, 09:54 PM
  5. It works!
    By Sleedo in forum CNC Wire Foam Cutter Machines
    Last Post: 12-16-2007, 10:53 PM
