586,047 active members*
3,960 visitors online*
IndustryArena Forum > MetalWorking Machines > Dyna Mechtronics > Dyna Em3116 Intermittent Boot Failure Help
Results 1 to 6 of 6
    Jun 2015
    8
    Hey Guys,
    I just picked up an em3116 that works great, until it doesn't turn on.
    In the mornings it sometimes just doesn't want to power up. The control LED's flash in sequence like they are supposed to, then nothing. The screen doesn't show anything, all the drive boards in the back have a Red Led and there are various LED's blinking in rapid succession on the main board int he rear case. A few attempts and power cycling will get it to come on, and then it has no problem turning on and off all day. I'm stumped.
    All the voltages look good with a multimeter, and without the display powering up I can't get any fault codes.
    Does anyone have a schematic for reading diagnostic LED flashes on the main board in the rear of the machine?
    https://youtu.be/ayD6ZlSEHEc
    Sep 2012
    106
    Re: Dyna Em3116 Intermittent Boot Failure Help
    i had the same issue with mine for a short time. the RAM had worked loose. Try taking the ram out of the main board, blowing out the connectors, and then reseating the RAM. wiggle it back and forth a bit while seating. any idea what software version you are running?
    Jun 2015
    8
    Quote Originally Posted by Third-Gen View Post
    Thanks!
    I'll give that a go.
    When it boots up it says Dyna V4
    Jun 2015
    8
    Reseated the Ram to no avail.
    Sep 2012
    106
    bummer. i took my whole control pendant apart to clean it out, it was full of chips. it could have been something else but the RAM trick fixed mine. Your software is quite a bit newer than my V2.2.
    Jun 2015
    8
    The machine has build stickers from '98 inside.
    I'm about at my wits end here I can't find any pattern here it's completely random.
    Before just randomly replacing obsolete equipment I'm considering just throwing some gecko drives and a breakout board on it and running mach3.
  1. Dyna Software Issue EM3116
    By Third-Gen in forum Dyna Mechtronics
    Last Post: 07-04-2022, 09:12 AM
  2. DYNA EM3116 Mill Questions
    By jomans in forum Dyna Mechtronics
    Last Post: 08-31-2019, 06:04 AM
  3. DYNA EM3116 Mill Questions
    By jomans in forum Knee Vertical Mills
    Last Post: 10-27-2017, 02:39 PM
  4. DYNA EM3116 Manuals
    By adnanahmad in forum Dyna Mechtronics
    Last Post: 08-05-2011, 12:32 PM
