586,082 active members*
3,534 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > I need the vendor settings file for Chinese SGH350 Laser with Ruida board
Results 1 to 8 of 8
    Feb 2018
    5
    Hi, I did a factory reset on my blue and white sgh350 laser, it has a Ruida board. 500x300 work bed. HMI-V4.1.13.
    Does anyone have the file or can instruct me as to how to configure it? I am using RDworks v8.0
    Jan 2008
    940
    Re: I need the vendor settings file for Chinese SGH350 Laser with Ruida board
    Try these they work for my unit
    Feb 2018
    5
    Thank you, I managed to get the correct files from someone yesterday, and it is now running again.
    Buenas: Tengo un problema parecido. El láser no dejaba de funcionar desde que empezaba hasta terminar, quemandolo todo. Si estaba haciendo un grabado, quemaba todo de lado a lado, de forma continua, y si estaba cortando algo, iba quemando en el trayecto. Así que restaure en la maquina a valores predeterminados, y después valores de fabrica, y ahora si que se ha desconfigurado por completo. Alguien puede ayudarme, o pasarme algún archivo para volverla a configurar? Muchas gracias
    Jan 2019
    Hi.would you ad this file with vendor settings please.Thank you
    Jan 2022
    hi marco can please send to me vendor setting file coz I have same machine like yours and I need that file
    Oct 2022
    pleas help me
    Jan 2008
    940
    Try RD8888
  1. Shenhui SH350 - need vendor settings file or screenshots
    By shenhui laser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-27-2019, 02:52 AM
  2. Converting from Ruida rdc6442s to controller with no file size linit
    By closeracing in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-08-2017, 08:01 PM
  3. Help creating vector file. Chinese Laser Engraver
    By ndar in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-12-2016, 03:11 AM
  4. Chinese Laser question (Bad Board?)
    By blairgr in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-24-2012, 06:08 PM
  5. Power and speed settings for Chinese Laser
    By cdmcali in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-24-2012, 01:53 AM
