586,100 active members*
2,713 visitors online*
    Dec 2014
    5
    NLX2500 load monitor
    Anyone using load monitor on NLX2500 Mori seiki.
    How do i use this function ???
    Mar 2017
    314
    Re: NLX2500 load monitor
    G313?
    tool load monitoring?
    Dec 2014
    5
    Yes Sir
    What is the correct way to program G313
    For example - if i what to monitor the X axis for a grooving tool (T0303)
    I have found the Menu for Load Monitor on the machine.
    Mar 2017
    314
    I never figured it out / I am not sure if Mori implemented it correctly. I never put much effort into it though. I know that the Tool Life counter is not working as the book says. The book explicitly say that when the life is up , cycle start is inhibited. It is most definitely not. I have tested it on several different Mapps controlled machines. The ones here at least.
    I have seen programs here from my predecessor that have G313 in them. but I think you have to "teach" the acceptable load to use it. I know that just having a G313 and some other data words is not enough to keep from burning up a partoff tool, verified.
    I use just some macro statements in the program to count tool usage by instance, preventing program execution if life count is reached.
    Dec 2014
    5
    Attached Thumbnails Attached Thumbnails IMG_20180301_185846.jpg   IMG_20180301_185853.jpg
  1. load monitor stuff
    By deadlykitten in forum Okuma
    Last Post: 04-24-2018, 07:25 PM
  2. U10M spindle load monitor and monitor mode
    By myhäje in forum Okuma
    Last Post: 02-21-2017, 08:45 AM
  3. okuma load monitor
    By Motiejunas in forum Okuma
    Last Post: 01-20-2017, 11:30 AM
  4. Load Monitor on (or not)
    By OkumaMori in forum Mori Seiki lathes
    Last Post: 07-27-2013, 03:35 AM
  5. Load Monitor
    By ChattaMan in forum Okuma
    Last Post: 12-19-2011, 08:10 PM
