586,075 active members*
4,283 visitors online*
IndustryArena Forum > Hobby Projects > Musical Instrument Design and Construction > Blender, Rhino, Aspire or Fusion 360 for guitar design and milling?
Page 1 of 3 123
Results 1 to 20 of 56
    Have been working with Fusion 360 for about 6 months and have milled a few guitar bodies both semi-hollow and solid and pickguards, done a little engraving - but making necks is proving to be rather difficult. Just wondering if any of the other programs are a tad easier to learn? After all, not interested in rendering or making models but real world guitars.
    Dec 2014
    640
    Re: Blender, Rhino, Aspire or Fusion 360 for guitar design and milling?
    I second that!!!
    May 2006
    803
    Lets, make them...........
    I see there is trouble with the tele neck model. ?
    I do neck surfacing on an older cad ( from last century ) ...
    And have no idea about fusion and its surfacing capabilities.
    Dec 2014
    640
    I've been mucking about in Fusion360 trying to get a neck profiled. I've basically had some success, but lots of tweaks to do.
    May 2006
    803
    Fretman, Do you have the profile at zero fret defined ? and the nut width ? thickness ? width at the heel pocket ? a sketch of your headstock design ? Cad file of the scale length ?
    it doesn't matter what system you have, it is a geometric procedure to follow.
    Dec 2014
    640
    I do have a profile at zero fret, nut width and width at heel pocket. What I've done so far is to do a loft of profiles from about the 15th fret to the nut. Then I extruded the heel and peg head shapes, then lofted between the neck profiles and the peg head and heel shapes. That got me a basic 3D neck...below. It does not have the fretboard attached.
    May 2006
    803
    Good start, this surfacing is tricky,
    it is all about the boundary and control curves
    I have had to teach this to many programmers,
    Not easy over the forum.
    I am using a year2000 software which can surface anything 100% control
    This shows the semi-hollow body, f-hole and picguard in Fusion and then after milling. Hey, looks like Fretman_2 is on the right track with that neck - how many planes did you have to setup for this?
    Dec 2014
    640
    I guess it was only 4 planes if I'm understanding you correctly. Two profiles at the nut and 15th fret each, then the heel and peg head shapes respectively. I lofted the two profiles together, then extruded the heel and peg head shapes, then lofted the three parts together. Next I want to understand the settings for the rough passes, then the settings for fine passes so I can generate the gcode. I'm going to do a test on a piece of pine.
    Quote Originally Posted by VGcustomsho
    p;2160148
    Here's the finished guitar
    Vegas Guitars Custom Shop
    http://vegasguitars.com
    Hi all! I have just ordered a laguna cnc with the rhino software for guitar building. I am brand new to cnc besides having my current guy cut my bodies on his cnc. He uses bobcad and aspire and has all my drawing in those programs. What format will Rhino take for me to be able to use those files?
    Thanks,
    Anthony
    Moxy Guitars
    Congratulations on your new endeavor! Heard great things about that machine and program.
    Dec 2017
    77
    Quote Originally Posted by moxyguitars View Post
    If all you want to do is get the shape of the solid into another program, and proceed with CAM, that may be possible to convert. But if you ever want to make any changes to the drawings that define the model, or other changes of that nature, you'll need to recreate it in the new program. (There are translators, and interoperability formats like IGES, but as a practical matter it's not likely to work.)
    35538
    A guitar neck is one of the most difficult things to model.
    Generally, learning the methods and processes is more important than learning the software. Meaning that regardless of the software, you'd generally go about it in a similar method, but using different commands, depending on the software.
    I would watch as many tutorials as possible, regardless of the software used, to see the approaches being used. You may find that there are much better methods to use, and learn things you normally would never think of on your own.
    There are a lot of tutorials on Youtube. https://www.youtube.com/results?sear...+neck+modeling
    I would expect Rhino to have a similar learning curve to Fusion 360, but it would be a quite different learning curve, as Rhino is a lot different from Fusion 360.
    But I would say that these two would be the best choice.
    Blender would have a steeper learning curve, as it has a variety of different types of modelling tools to use. But it's free.
    Personally, I would not recommend using Aspire as a 3D modeling tool. It's designed to model 3D reliefs, and is not a CAD or 3D modeler. I know that quite a few people use it as an all purpose modeler, but I don't think it's the best choice.
    Thanks much - been watching lots of youtube videos - very few good neck videos - only a couple really that are of a high enough quality to learn techniques from. That said, the best is a guy in England that makes a neck in Rhino - it looks much easier to do than in Fusion. Haven't see necks done in Fusion that are quite sleek enough IMO - nearly every one has a serious flaw or weird transition or loft. Not that it can't be done - just haven't seen one done with a nice gradual smooth transition between headstock and neck or neck and heel. Most of the gallery guitar photos are of models with fretboards, frets, side markers, nuts, fret markers, truss rods, etc. - all the stuff that isn't needed in milling a guitar with a CNC - I can prepare a fretboard in a fraction of the time it takes machine to mill - so really only need the neck contour, profile and truss rod channel. Apparently I'll just have to keep plugging away in Fusion. Rhino is too expensive for me currently.
    Thanks very much for the advice - recently have been trying to find a program that I can actually own - BobCAD price was high but they agreed to give me the package for the hobby fee - so now I can dedicate my time to learning one program that isn't cloud based - at least that's the plan. Spend about 4 hours last night working on necks in Fusion and made some progress - did it by watching videos as you suggested. The best one was a BobCAD video that shows a great way to transition and loft neck areas . . . again many thanks for sharing your expertise!
    Mar 2018
    5
    +1 to Rhino (and addons of course)
    I'm not a designer, the most of my work is 3D scanning and reverse engineering. That's why in the most cases I'd rather have a 3D scan model and modify it instead of creating from scratch =)
    Apr 2014
    432
    That young guy gives a good insight / explanation on Rhino based on the others I have seen I think it would be the way to go .Even if you got the c shaped neck profile done and hand finished the rest you will see most big shops hand finish anyway,just a few thoughts .
    35538
    Unfortunately, YouTube doesn't screen for competency. If it did, there would be a lot less videos.
Page 1 of 3 123
  1. CURSOS DE SOLIDWORKS, FUSION 360, ASPIRE Y ROUTERS CNC
    By karloterrazas in forum Mexican Club House
    Last Post: 08-29-2016, 05:34 AM
  2. Guitar Design using photos into Rhino
    By rim basses in forum Rhino 3D
    Last Post: 12-30-2010, 10:28 PM
  3. Tutorial: Rhino, Cut3D, and Vcarve Pro to make a guitar body..
    By konalure in forum Musical Instrument Design and Construction
    Last Post: 06-08-2010, 10:19 PM
  4. Irregula Guitar Surface on Rhino
    By NCN in forum Rhino 3D
    Last Post: 03-24-2006, 06:20 PM
