586,110 active members*
3,313 visitors online*
    May 2006
    60
    Bending Spring Steel
    Hello All,
    I would like to bend some replacement spring tool fingers for my mills ATC, I need 3 replacements.
    attached is a scale drawing of the spring and a picture.
    I bought some 1075 Blue spring steel but it too hard to wrap around without breaking.
    So my question is: do I want to use what I have and anneal and then re-harden the bends or buy anneal spring steel bend and then harden.
    Bryan
    Attached Thumbnails Attached Thumbnails 720 tool holder clip.pdf   20180220_193715 (Large).jpg
    Apr 2004
    5737
    Re: Bending Spring Steel
    You could do either one. By definition, spring steel will spring back instead of bending, so you need to bend it in an annealed state, then harden and temper it to blue.
    Andrew Werby
    Website
  1. Steel Bending Question
    By thegolfer in forum Mechanical Calculations/Engineering Design
    Last Post: 07-26-2015, 11:47 AM
  2. machine spring steel
    By magnum500sw in forum MetalWork Discussion
    Last Post: 06-01-2013, 06:09 PM
  3. RFQ: Spring Steel plates
    By Katana Man in forum RFQ (Request for Quote)
    Last Post: 03-09-2012, 11:07 PM
  4. Spring steel Q
    By binfordw in forum MetalWork Discussion
    Last Post: 12-26-2010, 05:39 AM
  5. bending of steel after milling
    By dhiruj in forum MetalWork Discussion
    Last Post: 03-23-2007, 08:29 PM
