586,104 active members*
3,431 visitors online*
IndustryArena Forum > CAM Software > Rhinocam > Need advice on CAD/CAM for 5 axis machining center, MultiCAM 8000 series
    Hi Guys
    i am currently trying to machine a tube on my Multicam 8000 series CNC router. I am machining in 5 axis and trying to machine around a tube but have an issue where it seems the Y axis is elongating when machining around the tube. The RhinoCAM software seems to be producing the correct cutting lines and the code matches the post processed file which makes us believe the problem is not in the post processing.
    We have programmed the machine to cut 180 degrees around a tube which its completing without any issue however as explained above and shown in the image below the Multicam machining is not following the programmed profile, it is machining the top surface of the tube correctly however as soon as it moves directly off the Z axis and into Y it seems to elongate. we have investigated online and found references to Y axis scaling and we’ve tried programming in different ways with the same issue occurring. Do you have an idea of what the issue may be? The pic attached below could help show the issue i am having. any advice is welcome. Thanks
    Feb 2018
    59
    Re: Need advice on CAD/CAM for 5 axis machining center, MultiCAM 8000 series
    alphacam has a nice 5 axis post for multicam
    keysoftwareservice.com
    Aug 2014
    232
    Possibly a problem with tool definition ? Ball vs Flat mill ?
  1. advice about vertical machining center
    By samu in forum Want To Buy...Need help!
    Last Post: 03-17-2015, 04:32 PM
  2. Considering Multicam MG series purchase - Need Advice
    By dcg4403 in forum Commercial CNC Wood Routers
    Last Post: 09-02-2013, 12:43 AM
  3. Multicam 8000 Series 5 Axis
    By welly2000 in forum Multicam Machines
    Last Post: 06-19-2012, 10:03 AM
  4. Seeking advice on machining center purchase.....
    By pete from TN in forum Uncategorised MetalWorking Machines
    Last Post: 01-29-2011, 02:17 PM
