586,117 active members*
3,394 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > BobCad Post Processors > Morbidelli Author 504 Post Processor
    Mar 2018
    4
    Cool Morbidelli Author 504 Post Processor
    Simply the post processor we use in BobCAD V26 for our Morbidelli Author 504.
    Mar 2018
    4
    Re: Morbidelli Author 504 Post Processor
    Update! :wee: I guess there was a bit more that my predecessor was putting in manually in a text editor after every post. :/
    I plan on updating this to remove redundancy in some values, such as setting the Z axis in every block, even though it's not changing. I also want to run WinXISO at the end of post to convert this to a PGM, so I don't have to do it on the mill controller after I post.
    If anyone has questions or comments, I'd be more than happy to help. Hopefully someone gets some use from this.
    Changes:
    03-02-2018 - Added SY=1 M=0 to File header.
    03-06-2018 - Added X0 Y=-stock_length to header. This offsets
    the Y axis by the length of the material.
    I also altered the ending X coord so as to move
    the work head away from the material
    automatically.
    Attached Files Attached Files
    Mar 2018
    4
    Lightbulb Re: Morbidelli Author 504 Post Processor
    Ugh! I jumped the gun a bit. X0 is supposed to be XO, and upon request, I changed the commands for boring, BO, to B. BO is optimized boring, and B is simply unoptimized boring, I guess. I'm pretty new to this. Here's an updated millpst.
    I changed some formatting of the changelog in the millpst to make finding corrections a bit easier, as well.
    - Changed X0 to XO, above. My bad. - Block 0.
    - Changed instances of "BO" - optimized boring, to
    "B" - unoptimized boring. - Blocks 800 to 831.
    Mar 2018
    4
    New update. Lots of changes to this. I'm not entirely sure how the CAD/CAM process went before, but now since I've started developing on my own, I'm developing everything in quadrant 1 (x+/y+). I've altered how drilling works, since it's not using optimized boring anymore. Here's a quick changelog. It's far from a complete changelog though. I have a hard time documenting things as I change them. So far this works flawlessly for me. No more changing offsets at the head.
    04-30-2018 - Removed XO which was the origin change command. It's
    not necessary if you're developing in quadrant 1.
    (x+,y+) - Block 0
    05-01-2018 - Added code to Block 50 for rapid movement.
    05-02-2018 - Removed 'work_coords' from the file, as it didn't
    seem to be doing anything useful.
    - Edited the boring commands (Blocks 81-99) to remove
    N="L", since that's only used in optimized boring.
    - Created Program Block 9, to properly set the drilling
    z depth. It was negative before which wasn't working.
    Applied Program Block 9 to be used in boring blocks
    81-99.
    - Added rotational speed and velocity to boring commands
    in blocks 81-99
    - Other small changes, like formatting cleanup.
  1. Morbidelli Author 503
    By num1040 in forum CNC Machining Centers
    Last Post: 07-22-2018, 10:49 AM
  2. Morbidelli Author 427
    By elktw in forum CNC Machining Centers
    Last Post: 08-14-2015, 07:40 AM
  3. Post Processor for Morb Author 213 any one please
    By auckcabs in forum Post Processor Files
    Last Post: 01-25-2015, 12:45 AM
  4. Morbidelli Author 344
    By tyretochka in forum CNC Machining Centers
    Last Post: 05-19-2012, 06:32 PM
  5. Morbidelli Author 430
    By Scooby Doo in forum Commercial CNC Wood Routers
    Last Post: 04-27-2012, 02:32 PM
