586,119 active members*
3,607 visitors online*
Page 2 of 2 12
Results 21 to 35 of 35
  1. #21
    Dec 2007
    25
    Re: 6040 CNCEST USB problems
    Quote Originally Posted by darkoford View Post
    Thanks Christian.
    Do you know what .dll for this BOB?
    RnRMotion.dll not work.
    No, but look on aliexpress or Taibao.com (might take VPN/translation).
    Do a search for USB BOB on google and then visit from where the photo came, sometimes works.
    -Christian
  2. #22
    Sep 2010
    26
    All settings are set according to the manual. The problem is with the PCI driver.
    Win7 Ultimate 64
  3. #23
    Dec 2007
    25
    Darkoford,
    Sorry you are having problems. I have run on Win7 Ult x64 with no problems, and my 6040 is currently running on Win 10 Pro.
    Only suggestion I have would be to try a different computer. My .dll is for the red board at the beginning of this thread.
    The blue board, I am not familiar with. This thread should be specifically for the BITSENSOR BSMCEO4U-PP USB BOB,
    which is the board in my 6040 which looks like this:
    Beyond that, someone else will have to help.
    The PCI issue appears to be a missing OEM driver from the computer mfg.
    -Christian
  4. #24
    Sep 2010
    26
    Thanks Christian
    I tried with 6 different computers and one laptop. With this configuration, it works but occasionally loses USB or freezes.
  5. #25
    Feb 2009
    6028
    My 6040 with USB uses the same RNR dll, I did have issues at first with loosing the USB randomly, then switched the USB cable to a heavy shielded one, never had a hiccup since.
    https://www.amazon.com/DTECH-10ft-Ca...18-spons&psc=1
  6. #26
    Sep 2010
    26
    I also tried with USB cable to a heavy shielded (as in the amazon link) but the same problems.
    USB Chip STM32F103.
    and installed his driver. In Device Manager, I deleted the PCI driver.
    Now he works much better but he is not good yet.
  7. #27
    Jan 2007
    626
    Thanks Christian
    Darkoford,
    Your PC is in the same enclosure as all of your electronics? Did a Electrical type person build it?
    I suspect Electrical Noise may be a big part of your problem.
    Some VFD's produce alot of electrical noise, some not so much. I depends.
    I would have thought it best to have your PC in its own case.
    Sometimes a single common earth point is needed, and is good practice anyway.
    Also screened cables help alot as well.
    USB is quite prone to electrical noise and some laptops tend to have less robust USB systems.
  8. #28
    Sep 2010
    26
    Sterob,
    I'm well known for electric noise but this is not the first machine I'm working on, but the first is this BOB model.
    I tried a few computers that were only connected to a USB cable and everything was the same.
    For four years almost everything works the same for me. 10 hours a day. (X-12m, Y-3m)
    https://www.youtube.com/watch?v=dvcp7C4jMAA
  9. #29
    Jan 2007
    626
    Ok, thats not the issue.
    Sorry to distract from the real issue.
    As you were....lol
    Sent from my SM-G920I using Tapatalk
  10. #30
    Sep 2010
    26
    Every suggestion is good.
    *The STM32F103 chip uses Arduino and no problems. Software, BOB driver is a problem.
  11. #31
    Hello, can you share the files im having the same problem
  12. #32
    Hello,sounds like i'm having the same problem with my 6040 you had with yours,can you share the info i need to set up march3
  13. #33
    Sep 2010
    26
    The error is in the software. You need to contact the BOB dealer to send you the original driver (RnRMotion.dll). So I solved the problem.
    The machine was sold so I don't have any more RnR.
  14. #34
    Dec 2007
    25
    Quote Originally Posted by nextimemike View Post
    NTM: it is Mach3 btw. You are going to have to explain what your problem is; not sure what you are looking for?
  15. #35
    Feb 2008
    92
    if anyone is looking for usb drivers I think this is it
    https://www.chinacnczone.com/en/usb-..._l282_p16.html
Page 2 of 2 12
  1. 6040 limit switch problems
    By wdp67 in forum Chinese Machines
    Last Post: 11-28-2017, 04:30 PM
  2. cnc 6040 alu problems
    By donminion in forum Chinese Machines
    Last Post: 10-14-2014, 08:55 PM
  3. CNC 6040 with 3 D head Shows problems
    By RodMcM in forum Chinese Machines
    Last Post: 02-04-2013, 01:33 AM
  4. CNC 6040 AND VFD PROBLEMS
    By justy22 in forum Phase Converters
    Last Post: 07-04-2011, 12:49 AM
