586,047 active members*
3,761 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > SPLIT CIRCLE IN GIBBS V12
    Oct 2017
    11
    In the old gibbs if i wanted to split a circle to have two point connected on each end it was plug-ins/geometry/ geo tools/ split circle. But i'm not seeing anything like that in the new gibbs update. Do i have to import the plugins or something or am i stuck to drawing it manually, which i also cant seem to do if i put two points at the xy positions along the circles radius once i connect them it turns into an arc and making another circle to make a mirrored arc doesn't work. I need a circle with two ponts connected to it at 90deg to each other in order to program the wire edm software we have.
    Jan 2009
    103
    Re: SPLIT CIRCLE IN GIBBS V12
    The one your looking for is GeoEdt-Split using equally spaced with a value of 2
    If you don't see that maybe you need to activate the geoedit.dll in plugin manager.
    you'll need to restart Gibbs to see it in the menu.
    Apr 2005
    88
    I am pretty sure this will do what you want... In the Plug-Ins dropdown click on Geo Edit Split
    Attachment 388856
    Then on Equally Spaced and define how many sections you want
    Oct 2017
    11
    Yes that was it Thanks Guys!
  1. A circle, a simple circle. How hard can it be?
    By camasaki in forum Hobby Discussion
    Last Post: 07-18-2019, 09:21 AM
  2. Draw line tangent from small circle to large circle
    By WEDDLETON in forum ViaCad / Shark
    Last Post: 07-30-2014, 05:53 AM
  3. Replies: 16
    Last Post: 02-05-2014, 08:21 PM
  4. write gcode for circle with 4 small circle inside it
    By Farzaneh_2010 in forum G-Code Programing
    Last Post: 12-13-2010, 05:24 PM
  5. Replies: 4
    Last Post: 06-12-2009, 04:32 PM
