586,070 active members*
3,514 visitors online*
Results 1 to 9 of 9
    Post BenchTop Mill to Buy
    Hi All
    I am going to buy a new small verticle mill. Either I will convert it to CNC or buy a mill from CNCMasters ready to go for $6000 with a base. The non CNC mills I am looking at cost about $2700. Did any body out there do this? Any info that you have would be welcome. Thanks in advance Lee
    Jun 2006
    2512
    Hi Lee,
    To put it straight I think you would be crazy to buy the CNCmaster.:nono: It's a round column RF30 clone. About the worst possible choice for CNC (at least when you are spending USD 6,000).
    If you want ready built at the USD 6,000 mark you should be looking at Tormach, Smithy CNC or a ready built IH.
    Tormach - has a track record but only one alternative (ready built) and no servo option.
    Smithy CNC - has a large range of build yourself alternatives but no apparent track record.
    IH - has the biggest envelope plus build yourself or ready built options but no apparent track record with the current owner.
    CNCmaster - is just a dinosaur.
    Opinions may vary.
    Regards
    Phil
    Quote Originally Posted by leeschaumberg View Post
    Hi All
    Smile Mill to Buy
    Philbur
    Thanks for the info. I'll check those 3.
    Lee
    Post Mill to Buy
    After some more looking and reading , I've decided on the IH mill/drill. This 2200 all manual mill has a 4500 CNC kit available. Weight of the mill is 950 pounds so it's not an X1. They use it to make thier parts so it works. To get all the info visit thier website at www.industrialhobbies.com.
    Jun 2006
    2512
    A kit works if you have the skill and time to make it work. Judging by your initial questions you are new to CNC. I trust you are aware of the job you are taking on with a kit. It’s not quite as simple as bolt together and go. If you figure your time is worth much more than about $5/hour you should reconsider the ready to run out of the box alternative. The only real advantages of "building yourself" is for the challenge and the knowledge you gain.
    If you go with the IH + kit you should join the IH forum on CNCzone. In fact I recommend you spend a couple of weeks reading through past posts before you decide on the kit. There is a mass of experience there.
    You will also need to think about lubrication, system way-covers, housing the electronics, etc, etc.
    Opinions may vary.
    Good Luck
    Phil
    Sep 2004
    412
    You need to state what your work envelope is and how much room you have to store one of these beasts.
    Also, what level of precision your expecting.
    I agree with the above posts reguarding the round columns. Ideally, you'd stay away from those.
    Smile IH Mill
    Philbur
    Thanks for the response
    Following are answers to your questions
    The Skill - Worked for 4 engine manufactures in Engineering and Research
    Fluent in electrical devices and wiring
    Very knowledgeable regarding mechanical devices
    Drag raced a stock 427 cu inch 425 hp camaro in A stock class
    Instrument rated Com pilot
    Com drivers license rated (ABCD and M)
    Many ((thousands of dyno runs)) on internal combustion engines
    The max was 5043 hp at 1000 rpm (4875 rated at 1000 rpm)
    Worked as a field service engineer
    Own many tools of all kinds
    Manufacture special snowmobiles
    Yes I'm new to CNC milling
    Any job can be long and difficult
    When I build it myself I learn alot
    I belong to a very good CNC forumn the CNC ZONE
    Lube oil not grease
    Way covers are good all the time
    The electronics and controls need to be securely mounted
    So I think I can fiNgure it out
    Deviant
    Machine 1 of 2 crankcase halves sized like a lycoming 360
    Precision should be comparable to normal crankcases
    The square column is the way to go
    Lee
    Jun 2006
    2512
    Sorry Lee, but it did seem that a person who switches from a plan to buy a ready to go CNCed round column to a IH + kit within the space of a few days could possibly benefit from some encouragement to research their plan a bit further, before laying done their time and their money.
    Manufacturing large, critical aeroplane engine components will certainly be a challenge.
    Good Luck
    Phil
    Philbur
    Lube oil not grease
    Deviant
    Lee
    Post Machine Engine Crankcase
    Phil
    Yes I wan't to machine my own crankcase. A flat four diesel. A two stroke diesel. A two stroke diesel has been built for a long time and is well proven. (THE DDA) Compressing the intake air is required to start and is good for a plane engine that flies at altitude. I'm sorry if my brain goes so fast. But my ESP is still garbage.
    Lee
  1. Has anyone seen this benchtop mill before ?
    By jeff2005 in forum Benchtop Machines
    Last Post: 02-11-2007, 04:46 PM
  2. Not Exactly a Benchtop Mill
    By dcprecision in forum Benchtop Machines
    Last Post: 09-28-2006, 03:58 PM
  3. i like this benchtop belt mill
    By ataxy in forum Benchtop Machines
    Last Post: 09-13-2006, 06:55 PM
  4. Bench for a Benchtop Mill
    By Novah in forum Benchtop Machines
    Last Post: 10-28-2005, 03:50 AM
