586,119 active members*
3,563 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Amada PEGA 345 04PC ALARM 401 & 444
Results 1 to 8 of 8
    Sep 2014
    15
    Hi, Anyone can help!!!
    My amada turret punch pega345 have this alarm code : 401 & 444
    444 error: Error has been detected in C-axis digital servosystem
    401 error: Servo (VRDY OFF)
    It happen when i start the machine. The NC led green light is not light up.
    I have also check the servo amp of C axis: a red led light up and display "HC"
    A16B-1200-0670/06A (PCB BOARD)
    A06B-6057-H402 (SERVO AMP)
    Please Help.
    Richard
    Oct 2005
    89
    Re: Amada PEGA 345 04PC ALARM 401 & 444
    hi,
    check if your 8400 on ward parameters are correct ?
    check if you have any broken wire from Servo Amp to C-Axis Motor.
    Is it a Hybrid Drive ( T&C Combined) or Individual Drive ( Amp) for C-Axis ?
    Mar 2009
    101
    Quote Originally Posted by richxantan View Post
    Please Help.
    Richard
    On the drive A06B-6057-H402 check terminal 3 & 4 this is drive enable signal. You need 100VAC if no power, check voltage on R3 & S3 at terminal strip. Do you have 100VAC? No? Check tripped circuit breaker.
    What LED on master board is on?
    I noticed you are getting HC alarm. High current. If above checks out, I would think one of the parts you listed have failed. Not likely C axis cable failed it never moves. I may have a drive you can try depending on your location. We can work out return if it doesnt fix your problem.
    Regards,
    Sep 2014
    15
    Quote Originally Posted by Pitre View Post
    hi,
    Individual Drive. We suspect due to lower auto index problem. Maybe due to chip stuck in worm gear. The auto index bottom, we realise, it is not smooth rotating.
    Do you have any drawing for pega 345 regarding auto index dismantle?
    Sep 2014
    15
    Hi, joe
    Thanks. HC alarm no more. But alarm 444 still appear. We suppect it is lower auto index issue. As we find out that, it is not rotating smoothly. Do you have any drawing for pega 345 on auto index?
    Maybe there is chip stuck inside.
    Sep 2014
    15
    Please Help.
    Richard
    Anyone have PEGA 345 AUTO INDEX DISMANTLE DRAWING?
    Need help and guide for dismantle and installation
    Oct 2005
    89
    hi,
    you will have the details in part list. Assly. Drawings and other details. Pm me if you dont have part list. Also let me know if the machine is Pega 345 / 345 K / 345 Q....they have diff. Style.
    Mar 2009
    101
    Hi, joe
    email me
    [email protected] I maybe able to help ;-)
  1. Replies: 6
    Last Post: 02-15-2024, 05:12 PM
  2. Replies: 2
    Last Post: 04-23-2022, 04:55 AM
  3. Amada pega fanuc 04pc system error
    By cndcnd in forum Fanuc
    Last Post: 10-10-2018, 04:47 PM
  4. Replies: 2
    Last Post: 03-08-2016, 05:31 PM
