586,072 active members*
4,578 visitors online*
IndustryArena Forum > Community Club House > International / Regional Forums > European Club House > Lathe - Carbon-Carbon Brake Disc Machining, Any ideas?
    Mar 2018
    4
    Question Lathe - Carbon-Carbon Brake Disc Machining, Any ideas?
    Hello All,
    I on the hunt for any information regarding machining Carbon-Carbon brake discs, used primarily in Motorsport.
    If anyone has done this before, probably a little niche, any info regarding Insert coatings and geometry also feeds and speeds - were talking CNC turning here.
    Thanks for any help in advance.
    Sam
    Production Engineer
    CNC Programmer, Setter, Operator
    Mar 2018
    12
    Re: Lathe - Carbon-Carbon Brake Disc Machining, Any ideas?
    Carbon-Carbon composite is the toughest, most heat resistant material we have on this planet and off... This is the stuff they put on the leading edges of the hypersonic SCRAM-jet.
    Are you sure you have to put it in a lathe? Might be a job for EDM.
    15362
    Quote Originally Posted by DrNos View Post
    A EDM would not be suitable to machine this material, it can be Milled Drilled or Turned without to many problems
    Mactec54
  1. Strength Carbon vs Stainless + Machining on Tormach
    By cordvision in forum Tormach Personal CNC Mill
    Last Post: 02-03-2016, 11:50 PM
  2. Machining Carbon Fiber
    By pbd1971 in forum MetalWork Discussion
    Last Post: 05-18-2012, 09:50 AM
  3. Hard machining vs. carbon
    By JIMMY in forum Hard / High Speed Machining
    Last Post: 11-17-2007, 02:00 AM
  4. Tools for machining solid carbon (not carbon fiber)-more posted
    By camcutter in forum Composites, Exotic Metals etc
    Last Post: 04-28-2007, 12:23 AM
  5. Machining Carbon Fiber Rod
    By cncadmin in forum MetalWork Discussion
    Last Post: 03-12-2005, 05:03 AM
