586,067 active members*
5,231 visitors online*
    Jan 2015
    80
    Wincnc or V carve pro
    Been reading here and there and i'm going to fire up my router master space saver 52 here shortly and i know it has Wincnc on it. i already have and been useing vcarve pro and its ok so far, i mean i'm still learning it! Wincnc sounds like a pain ? if i can figure out how to hook up the power supply to the router i can find out...anyways i like vcarve pro 9.0 any advice would be great. thanks
    Re: Wincnc or V carve pro
    What is your question?
    WinCNC is the control software, and V Carve Pro is the CAD/CAM software.
    You use both, as they do two different things.
    V Carve Pro creates the g-code.
    WinCNC reads the g-code and controls the machine.
    Jan 2015
    80
    Well i'm not sure now.. i thought if i install vcarve pro 9.0 and do a project like i do on my smaller iconic machine after setting it up to carve it would just carve.. so the wincnc is what runs the router master. so when i make a bitmap to vector and size it and set the tool, the wincnc takes it from there ? am i thinking this all wrong ? look i just been carving for a year now and started out with the oliver 1013 and got the iconic 2015 and working it through vcarve pro 9.0, this 4x10 router master 52 is a differant animal.. i can't just insert the fd and away i go i know, i need to have the computer hooked up to it to work it and the wincnc just threw me, but if they work together i guess i'll find out, it will work or it will not ? still learning...
  1. Wincnc
    By fixtureman1 in forum Camaster
    Last Post: 01-27-2016, 03:47 AM
  2. WinCNC
    By cpworkshop in forum WinCnc
    Last Post: 04-28-2015, 10:14 PM
  3. Does anyone use WinCNC?
    By dmgdesigns in forum Uncategorised CAM Discussion
    Last Post: 12-06-2009, 04:55 PM
  4. NEED WINCNC HELP!!!!!
    By DietzWoodPROD. in forum WinCnc
    Last Post: 07-23-2009, 03:03 AM
  5. NEED WINCNC HELP!!!!!
    By DietzWoodPROD. in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-11-2009, 09:48 PM
