586,106 active members*
3,271 visitors online*
IndustryArena Forum > Material Technology > Vacuum forming, Thermoforming etc > Mould Design? Detail possible with 3mm ABS?
Results 1 to 3 of 3
    Mar 2018
    18
    G'day everyone.
    I'm new to this.
    Therefore, I am after some advice before I go go making my first mould, and my question basically boils down to this: How much detail can I get from 3mm ABS?
    More specifically, I want to make a part with an area like the pictures below.
    Would the ABS full fill those circled areas completely, ie, would there be a sharp edge? Or, would it not fully fill the tight angle leaving a more rounded corner?
    FYI, the pics are not drawn perfectly to scale, but the measurements are correct.
    Attached Thumbnails Attached Thumbnails 20180309_114116.jpg   1520554739989.jpg   1520554788370.jpg   1520554823629.jpg
    Feb 2006
    196
    Re: Mould Design? Detail possible with 3mm ABS?
    GOM,
    With vacuum forming,you most certainly will get some sort of radius in those corners.
    You might do better with pressure forming for more detail.
    I don't think you would get sharp corners on the outside surfaces in either situation.
    Doug Pryor
    David Wolfe Design, Inc.
    Akron, OH
    www.davidwolfedesign.com
    [email protected]
    Mar 2018
    18
    Just to be clear...I want the radius on the corners. I just wanted to make sure the small 4 by 6mm detail would come out with 3mm ABS.
    Amd yeah I just drew the drawing with sharp corners on the outside as it was easier to draw....and just a demonstration. I dont actually need sharp corners on the outside.
    Thabks
  1. Design Every Detail with AutoCAD 2015
    By cncadmin in forum News Announcements
    Last Post: 03-27-2014, 04:10 PM
  2. VX Mould Design, Mechanical and Cad Cam Software Seminars in Australia
    By Kookaburra in forum Trade Shows / Webinars / Other Events
    Last Post: 02-21-2008, 05:33 AM
  3. VX Mould Design, Mechanical and Cad Cam Software now in Australia
    By Kookaburra in forum News Announcements
    Last Post: 02-21-2008, 05:29 AM
  4. A question of detail
    By dherbman in forum DIY CNC Router Table Machines
    Last Post: 03-03-2004, 10:34 PM
