Need some R/C truck parts made. Have plastics, need aluminums or titaniums. May need many sets eventually if they go well. Will pay $.
Upload some of the CAD drawings and I'm sure that some of us here will be able to help you out
What parts do you need to make?
Aluminum is pretty easy to machine, for titanium you might need to contact the more advanced machinists here like hardmill, huflungdung, or highspeed
Look forward to seeing the plans,
Tei
-Please check out my webiste-
http://www.teilhardo.com
Which program can I use that is free or relatively cheap to design the CAD drawings on?
If it is a simple part you can draw it in Microsoft paintbrush. which comes with windows. If you need something more complex I suggest the demo version of Rhino but it will on save 25 times.
http://www.rhino3d.com/download.htm
Learning any CAD package is not something you do overnight. With dimensions and separate drawings for special features you should be able to get your points across using paintbrush.
if you already have the parts, pictures might do. Just a thought
Ed
I do contract programming and CAD. I can make your drawings for you in most any format you may need. Also can provide parametric models. $50 minimum. $35 hour. Minimum due up front. Files delivered C.O.D. USPS. Would need the part to draw it. I highly respect proprietary rights and have numerous satisfied customers. I do not do machining but do have sources. Aluminum would be substantially cheaper than Titanium for raw material and machining.
David
Experience is what you get when you don't get what you want.
What kind of parts are they? I have 5+ years or experience in RC with a couple years in Cad. If it's as simple as a shock tower, the price should be around $30.
Proud owner of a Series II Bridgeport.
