586,102 active members*
2,668 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > GRBL missing steps when jogging and de accelerating
Page 2 of 2 12
Results 21 to 22 of 22
  1. #21
    Mar 2015
    410
    Re: GRBL missing steps when jogging and de accelerating
    Turn down the acceleration and max speed 90%. If it solves the problem start increasing the speed until the problem comes back. At some speed(s) there can be resonance in de stepper driver causing irratic movements. I test my max speed by very very slowly increasing the speed. You can than hear the resonance. Every time you pass this speed (during accelerations), you may lose steps. Lowering the power supply voltage may solve this problem.
    In my software if found the next lines, added once i solved a similar problem:
    //According to GRBL config.h: !!!!! MinStepPulseTime + direction delay time must not exceed 127 !!!!!!!
    //Found that running at 70 us results in slow max FeedRates
    //keep lower than 35 us for good results
    I also have a chinese board with a realy bad design (Smitt Trigger before the optocouplers). I bypassed the optocouplers to get it working.
    I use TB6600 drivers (TB6560 also). Some say that leadshine drivers are better (getting more speed) but if you don't want/need to get the most speed from your machine, i thing the cheaper drivers will do. What i have read on several forums is that Gecko drivers are the best. But for those you pay top dollar. As soon as i have the time, i am going to build my own driver, i bit like smooth stepper and Gecko, but based on TB6600.
  2. #22
    Mar 2015
    410
    James,
    I have looked at your config file.
    -Try setting the step pulse time a bit longer Set $0 to 30 (max rate will be 16.67 kHz)
    -Try setting the step idle delay a bit longer Set $1 to 25
    According to the datasheet, your driver chip should do well with 1 us delays. So this should not be a solution.
    I use these setting on my TB6600 drivers and i never miss a step.
    Try jogging using CNCL, i should work well.
Page 2 of 2 12
  1. NEED HELP... missing steps
    By David57 in forum Gecko Drives
    Last Post: 05-01-2017, 12:18 AM
  2. Missing Steps?
    By wbleeker in forum Tormach Personal CNC Mill
    Last Post: 04-05-2013, 07:30 AM
  3. Missing steps
    By kasari in forum Commercial CNC Wood Routers
    Last Post: 01-21-2010, 02:14 PM
  4. Missing steps when jogging in more than one axis
    By vonnieda in forum Benchtop Machines
    Last Post: 08-05-2009, 06:23 PM
  5. Losing steps, smooth jogging, choppy running.
    By Ranscon in forum Automation Technology Products
    Last Post: 10-26-2008, 10:19 PM
