586,067 active members*
5,340 visitors online*
Results 1 to 12 of 12
    Mar 2018
    9
    Prismatic Machining to Mach3
    I am new to the CNC world but I do have a lot of experience in Catia design. I've always wanted a CNC router so last year I built one. I have Catia Prismatic machining and my CNC uses Mach3. I have very little knowledge of the prismatic desktop and am trying to understand the method of exporting the code that the Mach3 uses. It appears that the Catia generates APT,CLF or NC codes. The Mach3 will only import .tap, .nc, .ncc or .txt formats. Can anyone give me some advise on getting from the PM to Mach3?
    35538
    Re: Prismatic Machining to Mach3
    Mach3 will read g-code files with any extension, as long as they are plain text in the appropriate format.
    Sorry, don't know anything about Catia.
    Mar 2018
    9
    This is the code generated from Catia, it is a simple block with a small pocket machined in the top surface.
    I load it into Mach3 but it does not appear to show anything in tool path
    %1000. G71
    N1 G40 G90 G80 G17 G1
    N2 G99 T1 L+0 R+.125
    N3 G90
    N4 G17 T1
    N5 G0 X-3.458 Y-8.976 S70 M6 M3
    N6 Z-.25
    N7 G1 X-3.544 Y-9.331 F1000 M8
    N8 Y-10.358
    N9 X-2.715
    N10 Y-8.956
    N11 X-3.544
    N12 Y-9.331
    N13 X-3.607
    N14 X-3.669
    N15 Y-10.483
    N16 X-2.59
    N17 Y-8.831
    N18 X-3.669
    N19 Y-9.331
    N20 X-3.732
    N21 X-3.794
    N22 Y-10.608
    N23 X-2.465
    N24 Y-8.706
    N25 X-3.794
    N26 Y-9.331
    N27 X-3.857
    N28 X-3.919
    N29 Y-10.733
    N30 X-2.34
    N31 Y-8.581
    N32 X-3.919
    N33 Y-9.331
    N34 X-3.982
    N35 X-4.044
    N36 Y-10.733
    N37 G3 X-3.919 Y-10.858 R+.125
    N38 G1 X-2.34
    N39 G3 X-2.215 Y-10.733 R+.125
    N40 G1 Y-8.581
    N41 G3 X-2.34 Y-8.456 R+.125
    N42 G1 X-3.919
    N43 G3 X-4.044 Y-8.581 R+.125
    N44 G1 Y-9.331
    N45 X-3.169
    N46 Y-9.983
    N47 X-3.09
    N48 Y-9.331
    N49 X-3.169
    N50 X-3.232
    N51 X-3.294
    N52 Y-10.108
    N53 X-2.965
    N54 Y-9.206
    N55 X-3.294
    N56 Y-9.331
    N57 X-3.357
    N58 X-3.419
    N59 Y-10.233
    N60 X-2.84
    N61 Y-9.081
    N62 X-3.419
    N63 Y-9.331
    N64 M30
    N999999 %1000. G71
    Nov 2012
    1267
    The above code runs perfectly fine in my Mach3 (cuts a small rectangular pocket).
    Does it show anything at all in the tool path? Got a screenshot?
    Mar 2018
    9
    Quote Originally Posted by CitizenOfDreams View Post
    Thanks for the reply, It seems that maybe I just dont understand how to operate the Mach3 yet. I will take another look at it tonite. At least I know now that my code is being generated correctly. I’m fighting the learning curve right now, thanks again.
    My machine does jog in all 3 axis although I do not have spindle speed controlled yet.
    Mar 2018
    9
    I guess I am stupid. There is not a path indicated in the tool path window. What am I missing?
    Here is the screen shot.
    Mar 2018
    9
    I am getting this error
    R i j k words all missing for arc.
    Nov 2012
    1267
    Quote Originally Posted by JeffKlein View Post
    Can you post your lines 110 and 120? You may be missing a "G1" there.
    See this post: https://www.machsupport.com/forum/in...?topic=13258.0
    Mar 2018
    9
    okay, I am gaining some understanding and have got simple rectangle pockets to execute and the mill is working. I believe This is a problem with how the post processor handles the curves or circles. Below the posted code is a screen shot of the error. Thank you for your help.
    N155 Z-.5
    N156 X-2.293 Y-5.782 F1000
    N157 G3 X-2.579 Y-6.094 R+.313
    N158 G3 X-2.266 Y-6.407
    N159 G3 X-1.953 Y-6.094
    N160 G3 X-2.266 Y-5.781
    N161 G3 X-2.293 Y-5.782
    N162 G1 X-2.295 Y-5.751
    35538
    You either need to modify the post processor, or find one that works.
    From looking at the code you posted earlier, there are quite a few things that could/should be changed for using the code with Mach3.
    Mar 2018
    9
    You either need to modify the post processor, or find one that works.From looking at the code you posted earlier, there are quite a few things that could/should be changed for using the code with Mach3.
    Ger21, thanks for the reply, I have been trying several different post processors. I am running Catia V5 and I could use a little advise on a good post processor, any suggestions?
    35538
    Sorry, I've never even seen Catia before.
  1. CATIA Prismatic Machining question
    By bigalexe in forum Uncategorised CAD Discussion
    Last Post: 12-25-2013, 06:56 PM
  2. CATIA Prismatic Machining question
    By bigalexe in forum Uncategorised CAM Discussion
    Last Post: 04-21-2011, 07:20 PM
  3. CATIA Prismatic Machining Circular Toolpaths
    By ledbed6b in forum Uncategorised CAD Discussion
    Last Post: 01-23-2011, 12:11 AM
  4. prismatic machining/programming
    By shape in forum EdgeCam
    Last Post: 02-08-2009, 03:45 PM
  5. Pro Engineer-Prismatic Milling or Production Machining
    By Klaus in forum Uncategorised CAM Discussion
    Last Post: 07-23-2007, 09:38 AM
