586,058 active members*
3,238 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Exporting DXF out of Bobcad v26...can't open in other apps
    Oct 2007
    446
    Question Exporting DXF out of Bobcad v26...can't open in other apps
    So I can bring in DXF from other programs no problem...but when i export dxf out of bobcad I can't open them up in the other app...anyone else have dxf export issues like this?
    Dec 2008
    4548
    Quote Originally Posted by airbrush View Post
    BobCad dxf export to MCAD = only 2d line geometry....
    What are you exportimg? Whats the error?
    Oct 2007
    446
    Re: Exporting DXF out of Bobcad v26...can't open in other apps
    yes only 2d spline .... tried bringing into a vector program...just came in blank...tried in my plotter sign software and came in...although some splines were shifted a bit...exported out of there again as dxf and brought it into my other vector program...
    Dec 2008
    4548
    So a good file to export....
    To check on a translator issue, you can run "arc fit" on your splines and see if that solves the import into the first app...
    If it does, there wont be much to do. It will just be a disparate translator issue.
    Oct 2007
    446
    yup seems like inconsistent dxf format options between diff apps
  1. WTF BOBCAD- why are you exporting my information?
    By vitality1371 in forum BobCad-Cam
    Last Post: 07-14-2015, 03:57 PM
  2. Bobcad V23 won't open (running XP)
    By Fendbass22 in forum BobCad-Cam
    Last Post: 06-30-2010, 04:40 PM
  3. Bobcad V23 Won't Open
    By zachf in forum BobCad-Cam
    Last Post: 09-29-2009, 07:26 PM
  4. Bobcad Will Not Open.
    By Stampede in forum BobCad-Cam
    Last Post: 10-05-2008, 05:59 AM
  5. IRC Channel for Open source CAD/CAM Apps
    By Death Adder in forum OpenSource Software
    Last Post: 07-25-2005, 02:05 AM
