586,058 active members*
3,930 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Help needed - Bridgeport Series 1 BOSS 4 - worked, now cuts big ?
    Aug 2017
    Hi
    I'm looking for some help with a problem that has me stumped.
    I have a Series 1 Bridgeport BOSS 4, it was a fully original machine, updated with a win Xp machine and hillbilly BOB driving the stock controllers. About 3 years ago on the last cut of a job the Y axis blew a fuse, it was cooked. So i replaced just that axis with a Gecko G213v and 72v switchmode PSU.
    This setup worked 2 years ago, I made parts.
    The machine sat idle for around a year and a half, I fire it up maybe a month ago. The xp computer struggles and takes some prodding but it comes back to life. (now it fires up no problem) I go to make parts and find that the Y axis is cutting big. 0.010-0.020 big over 1.000" cut. X axis is holding tolerance fine. I've tried checking travel with an indicator and it appears to be in spec. The cuts are consistent, consistently over-travel in the Y.
    I'm stumped as to what could be causing the problem? or what would have changed over 2 years from sitting idle?
    help? any ideas?
    thanks, TT
    Dec 2013
    5717
    Re: Help needed - Bridgeport Series 1 BOSS 4 - worked, now cuts big ?
    Electrical noise throwing a few extra steps on the Y axis maybe? Loose connection? Some moisture in the system after sitting? A little corrosion on one of the connectors? Maybe a spider in the works?
    Jim Dawson
    Sandy, Oregon, USA
    Jul 2007
    31
    I am having some similar problems. I just got my retrofit done and I am milling some holes in .5 AR400. My holes aren't coming out round. They seem to be kind oblong. I haven't gotten a chance to take real good measurements but they are over size which would make sense if I was getting extra steps. The crazy thing is that it seems to be very consistent. I spiral out to final diameter and I can hear the machine working harder when it gets to the upper left and lower right quadrants on every revolution. I return to 0 and it's always off. I wonder if my cheap china VFD is part of the problem
  1. Bridgeport Boss 6 Series II
    By grigsby in forum Bridgeport / Hardinge Mills
    Last Post: 09-29-2012, 03:37 AM
  2. Bridgeport Series 1 cnc Boss 5
    By pyroboby in forum Bridgeport / Hardinge Mills
    Last Post: 09-01-2012, 11:44 PM
  3. bridgeport boss series maintenance manual needed for z axis timing belt change
    By ajitsingh in forum Bridgeport / Hardinge Mills
    Last Post: 11-06-2008, 04:57 PM
  4. Bridgeport Series I Boss 4
    By millwrightguy in forum Bridgeport / Hardinge Mills
    Last Post: 06-28-2007, 02:07 AM
  5. Bridgeport Series 1 CNC w/ BOSS 5 serial cable needed
    By bbuonomo in forum DNC Problems and Solutions
    Last Post: 05-30-2005, 11:05 AM
